I'm in the planning stages of having a bike built from Columbus XCr.
The frame would be on the small side with an effective 51 cm top tube.
And because the overall frame is on the small side, it will be naturally stiff due to the smallness.
Being that I'm 130 lbs, and the frame being a small size, I'm not worried about the frame not being stiff enough. In fact, I'm worried that it might be too stiff. I have read one custom builder mentioning in his blog that XCr steel rides very nice especially in a large frame. Given the same tubing, a larger frame will have more flex than a smaller frame
So my question is, should I consider going with traditional geometry as opposed to a compact geometry? Traditional geometry will make the frame have longer actual seat stays, longer actual seat tube, and longer actual top tube.. and these longer dimensions will make the frame more "flexy", give the frame an overall greater compliance and suppleness. Correct?
I fear that if I go compact, my frame will ride like a brick over bumps, which totally defeats the purpose of me building a steel bike.
thoughts?
thoughts?
