1 - 17 of 17 Posts
I’ll be getting a 2nd Road bike at the end of the week (tomorrow) and this bike will have standard 39/53 chain rings (My Choice). My current bike will remain 34/50 compact. I plan to train and race crits with the standard setup and I plan on racing hillier road races with the compact.
I have two questions:
1.Will I develop bad techniques like this: Should I stick with one or the other?
2. Is there a significant difference (effort) when climbing with a compact vs. standard?
a gear is a gear, does not matter which chainring/cog combination it takes to get there. what may irritate you is the difference going from one chain ring to the other.
I rode a standard 53/39 (or 52/42) set up for decades. A few years ago, I was building up a new bike and decided to try a compact set up. I'm not getting any younger, or thinner, so I thought it might be a good change. Frankly, all I noticed was that I could run a 12x23 cassete in place of a 12x25. Yes, you can get more gear on a given cog size with the compact configuration. But since you have 10 or 11 cogs, you can also shift.
One worry I had was running out of gear on a 12x50, versus a 12x53. It hasn't been a problem. So, get what you want and don't worry about it. I guess the one redeeming feature of a compact is that you have a little more gearon a given cassette , which helps if you're riding really steep roads.
So. Calif.
Things I've noticed racing & training on my 50/34 cranks, against others with 53/39:
Trained, experienced cyclists who race, often have self-selected or preferred cadences within a pretty narrow range.
In mid-cassette, consider the change from a 17 to 19t cog: about 12%.
Whereas, the difference between a 53 & 50t chainring is only 6%.
You "may" find yourself pedaling at a non-preferred cadence, to stay comfortably in the pack, depending on the speed.
In a road race with steeper downhills, you may find yourself "spinning out" with 50/12 gearing. You'll probably want a cassette that starts at 11t. 50/11 is a little "harder" than 53/12.
Even on very slight downhill (~1%) sprint finishes, I'm nearly spinning out in 50/12 (we're going nearly 40mph). Again, an 11t cog is desireable.
Few months ago I damaged my 50/34 crank and borrowed a friend's 53/39 crank. There was an adjustment period going back & forth between cranksets, much more so than simply changing cassettes (which I do fairly often). I would find it annoying switching between bikes with different cranks. Your "intuitive" shifting habits, that you normally do without thinking, are changed.
There most definitely is a significant difference in climbing. 39 vs 34 ring is 15% difference for the same rear cog, and is equivalent to 1-2 cogs larger. I prefer to spin faster uphills -- works better for me than "grinding" -- so the compact is a real benefit, especially for those of us who don't have 300+ watt threshhold power ;-)
Having said all that, I like the idea of a "mid compact" 52/36 gearing and will probably install that when my chainrings wear out. It has the same 110mm bolt circle as 50/34, so fits on the same crank.
I go between standard, compact, triple road and triple mtb without thinking much about it. Triple is a bit bothersome in that it requires more front shifting. Otherwise, it's just a matter of whether you run out of gears on climbs or in descents.
Will you be bothered by dropping into the small front ring more often? Will the ratios of the cassette be as close? If there is a big gap in the cassette to get to the gears for hills you may hate the big drop off in cadence when you shift.
I just went with 11speed, 50/34 12/25 cassette. the ratios are very close and I am always able to keep my cadence where i want it. I am not maxing out the top speed of the bike (if I am every doing 40mph plus its not because I am in top gear at 100+ rpms), but I figure it will be easier to switch cassettes down the line than crank and chainrings.
The compact 34 ring allows you to spin a bit more going uphill. I have some steep sections where even at a 34-26 my cadence will be in the 40's out of the saddle. I can't imagine doing that in a 39x23. On the other end of the spectrum I run a 50x11. If I spin out of this in a tailwind or downhill sprint, having a 53x11 isn't going to make that much of a difference. You might be able to spin a 110 RPM with a 53 instead of 116 RPM with a 50. Nothing night and day, but I would get the 11 on the cassette.
When I used a compact people used to kick sand in my face but as soon as I switched to a standard men wanted to be me and women wanted to be with me.
Or, as said already: A gear ratio is a gear ratio and it matters not whoch crankset you get it from. I have both and it really doesn't matter to me which one I use.
Roadbike Rider
I would suggest that you get compatible equipment so you can switch the compact and 53/39 between the bikes if you want.
I just got a compact equipped road bike after riding a 53/39 and find that I need a few rides to get used to it
There just seems to be more front chainring shifting with a compact as the (most) usable gears seem to be at opposite ends of the cassette.
which was not what I was getting at; the to stay at roughly same cadence going from small to large chainring is 2 cogs on a standard and 3 on a compact. roughly speaking.
Fred the Clydesdale
Real men don't have compacts. Go big or go home. :)
I don't own a compact. Well, I own a compact car. I have a bike with a triple that I haven't used in a year (50/39/30). I now have two that have a 53/39. I find I can climb whatever is around here with this gearing, but here is mostly rolling hills or flat.
The compact basically gives you close to the same gearing as a triple, but with two chainrings.
I just went from an 11-23 x 39-53 to 12-25 x 42-53 and increased my low gear range by a little doing so. Since I average around 20mph on my rolling course, the 42T ring allows me to avoid shifting to my big ring as often.
1 - 17 of 17 Posts
