1 - 20 of 26 Posts
Can anyone tell me what the difference in the ride between a compact and standard frame. I understand there is personal preference for size. Have had several different reaponses from LBS and other sources :confused, some say compact rides faster, standard is for longer rides; compact lighter than standard, or compact for women. Any input appreciated. Have narrowed down to Litespeed Ti and trying to decide on model.
eminence grease
As far as I'm concerned, there is no difference whatsoever. I own several of each and they ride the same. They don't ride faster, they're just as good on long hauls and while they can be lighter, they can also be heavier. Buy one if you like the looks (I do), if you need the extra clearance (I don't) or if you're in love with the paint job.
... with tons of other factors to consider... and in the context of your question... there ain't a lot of differences...
Compact may be more of a manufacturing technique than blanket tangibles that apply to all frames built to these specs... your personal preferences/needs should take precedence over compact v standard.
Compacts are made to save the manufacturer money. Personally, if I dole out big bucks for a frame I don't care to have the manufacturer try to shave costs; it's an insult. I want the correct size down to the centimeter.
Besides, compacts are fugly.
AMEN!
The technical difference between a compact frame and a traditional frame, is the compact has a sloping toptube while the traditional has a level toptube. So on a compact you have more seatpost showing and standover clearence than a traditional frame. Traditionally, frames were measured by the distance from the center of the bottom bracket to the center of the toptube, top of the toptube or even the tope of the seattube, depending on the manufacture with Center of toptube being most common. Compact frames are usually measured by toptube length.
The important measurement when finding a proper sized bike is toptube length. Standover height only matters to the extent that you can stand over the bike, whether it has 1" or 4" of clearence doesn't matter.
As far as ride differences, there is no way to tell how a compact frame will ride compared to a traditional frame, as there is no way to predict how any frame will ride. Frame materials, tubing diameters, and tube thickness all play much more into how a frame rides than compact v. traditional.
Finally, just to throw in my thoughts on litespeed. Litespeed builds some nice bikes, but unless they are on sale at 25% off, I believe them to be overpriced. I would suggest you check out some other TI manufactures like Seven, Moots and IF before plopping down the money. Finally, you may want to check out Dean, they make great frames, but their wait time is 3-4 months (they will tell you 6 weeks, but it isn't true).
Bike Dude
subtle differances
I've been riding a slightly sloping top tube frame for close to a year now and there is a differance in the way the bike handles compared to my more traditional steel frames. I've always sized my bikes by the top tube length and not the height which you can compansate by the seat post. Unlike the traditional frames I'm used to, my new compact frame seems to excellerate faster and climb faster due to short chain stays, or is it just the new bike feel? My frame is 853 Reynolds tig welded and can feel a little whippy. The one fundamental thing I've observed by talking to other compact frame owners is even with the same top tube length as a traditional frame you wind up going with the next size up in length for the stem. After I changed my stem to a 12 I find the bike more comfortable and stable. I can let go of the bars on the straight roads with no hip "english". Anyone else experiance this? Don't be afraid to try something new.
Unless your frame is of the exact same material, using the same size tubing with the same thickness and has the same head angle, seat tube angle, bottom bracket height, chainstay lenght, and headtube length, with the same compenents down to the tires, you have no idea if it is because your frame is a compact design that makes it feel different or something else. Any other thought is pure speculation.
Discussion Starter · #9 ·
Thanks for the input-- I will look at the others manufacturers before I make th final decision...
eminence grease
Hasn't been my experience - I ride a 120 stem on every bike I own, compact and traditional unless they are purposely sized down a bit. They all have the same reach, same bar height, same everything. The only bikes I ride a 130 on are traditional design.
I can't for a minute imagine why you'd change the stem length due to compact design if the virtual TT length was the same as the TT length on a traditional. Sounds like superstition to me. After all, 57cm is 57cm (at least in my case, using my tape measure.)
I only have a semi-sloping frame to compare a traditional frame to (Fondriest Carbon Lex - Cannondale CAAD7). Aside from the seat tube, they both are practically the same size. The CAAD7 has a 5mm longer effective top tube length, the BB drop is 4mm more than the Lex, and it has a 0.5 deg steeper head tube. For the remainder all other dimensions are basically with-in 1-2 mm. I use the same stem and bar set-up on both. Wheels and other components are basically the same as well. The response of the Lex feels quite a bit quicker however. Probably more due to a combination of better stiffness, the slightly smaller BB drop, and a bit over a pound less weight, than the slope of the top tube. I guess perhaps a lower CG might play a role as well....who knows......
Bike Dude
stem
First of all, stop the "virtual" talk. Try "actual" TT length, yes I measured it. Sounds like you have a pretty nice fitting frame for your compact. Just my experiance and that of a few others. After riding for a few years I know when to change the stem length. Now, if you want to talk "superstition", talk to my VooDoo Wazoo. LOL.
eminence grease
I guess I'm not sure how you measure, but on a sloping frame the actual TT length is not the same as the virtual TT length. Unless of course you're using a 90 degree STA. The virtual length (as in the actual horizontal length) is what determines the reach.
Maybe that's why you and everyone you've ever asked (except me) changed stem lengths?
Bike Dude
TT length
I respect your views but keep in mind my TT is only slightly sloping unlike some of the more radical designs I've seen out there. Merlin (I think the Cienna?) comes to mind.
It doesn't matter that it is slightly sloping, measuring the actual toptube length on any frame other than a frame with a toptube that is parallel to the ground will result in an error. Lets take a couple of examples:
57cm c-c traditional frame, Actual and effective toptube = 57
57 cm Compact frame, 52cm cc gives us a 5 degree slope (5cm/57cm Inv Sine = 5 degrees), with a 57 cm actual toptube and a 56.8 cm (5 cosine x 57 = 56.8).
57 cm Compact frame, 47cm cc gives us a 10 degree slope (this is a semi-compact frame like a Klein Aura), with a 57 actual toptube and a 56.1 cm effective toptube.
57 cm Compact Frame, 42 cm cc gives us a 15.25 degree slop (a real compact) with a 57 actual toptube and a 55cm effective toptube.
As you can see a semi compact frame reduces the effective toptube length by 1 cm and a real compact frame reduces it by about 2cm. This is why virtual toptube is so important, as it measures the actual length for figuring cockpit length and allows valid comparisions between frames of different sizes.
Sorry if it is confusing to you, but basic trigonometry dictates the rules, and while you may not like it, Virtual toptube length is the only easily comparable way to measure sizing on bike frames that depart from the old toptube parellel to the ground designs.
cdmc said:
It doesn't matter that it is slightly sloping, measuring the actual toptube length on any frame other than a frame with a toptube that is perpendicular to the ground will result in an error.
Would someone please post a picture of a bike with a top tube perpendicular to the ground? I for one would like to see one...
Not Banned
just a cost saving measure
they'll sell ya on it makes the frame stiffer (smaller triangle) but strength has to be 'lost' in loooong seatpost. I don't mind the slightly sloping, but compact are as UCH said fugly
( wow we actually agree) especially in larger sizes. I don't mind them as much in small frames but anything over 57 c starts losing its attractivness IMHO. I don't like them looking like MTB's, but then again I am a tad of a luddite.
Bike Dude
For TerryB and cdmc
Thanks for the info fellas. Makes kind of sense to me. Probably explains the requirement for a stem one centimeter in length longer.
1 - 20 of 26 Posts
