1 - 20 of 28 Posts
hello everyone
if I ride on a flat road into ~20 miles/per/hour headwind (~32kmh) how many degrees of gradient does it compare to, approximately? I am just looking for basic approximations, in absense of any hard data.
thanks
Is usually on MTBR.com
i used this:
http://analyticcycling.com/ForcesSource_Page.html
and according to it... riding at 15mph directly into a 20 mph wind looks like this:
Standard (gmf) % Test (gmf) %
Total Force on Rider 4598.7 6602.0
Wind Resitance 3825.1 83.2 5609.6 85.0
Rolling Resistance 304.5 6.6 304.5 4.6
Gravity Force 0.0 0.0 0.0 0.0
Drag on Front Wheel 268.0 5.8 393.1 6.0
Drag on Rear Wheel 201.0 4.4 294.8 4.5
Riding up a 6% grade looks like this:
Total Force on Rider 5659.7 6627.2
Wind Resitance 702.0 12.4 1563.8 23.6
Rolling Resistance 304.5 5.4 304.5 4.6
Gravity Force 4567.2 80.7 4567.2 68.9
Drag on Front Wheel 49.2 0.9 109.6 1.7
Drag on Rear Wheel 36.9 0.7 82.2 1.2
therefore the answer is: a little less than 6% at 15mph, weighing what the "dummy" weighs...
The hard part about that equation is that wind resistance is a function of the cube of the wind speed (to the power of 3) Thus, the resistance is less if you are riding at 10 mph into the wind compared to 20 mph into the wind. The resistance added by a gradient is constant regardless of how fast you are going.
That being said, I would throw out that a 20 mph wind at 15 mph riding speed is like a 5% grade. That is not based on anything scientific, just recollection of a few rides. (However, I am an estimator by trade and I did stay at a Holiday Inn Express last night)
Edit: Judging from the post that just beat me in, my estimate was about right. I was thinking 6% but knew that was too much.
Professional Lurker
Drag (or wind resistance) is proportional to velocity squared (as long as you aren't in a Stokesian environment :rolleyes: ). Required power to overcome drag is proportional to velocity cubed.
Resistance going up a hill (neglecting wind resistance) is independent of speed. Power required to go up a hill is thereforemerely proportional to velocity.
I'd rather climb a steep hill than ride into a strong wind anyday, but there have been many times I've climbed steep hills into a very strong wind. Wind does blow down hill! And it is often very windy on mountains.
Windrider (Stubborn)
This is only true.......
iliveonnitro said:
Realize that different muscles are used during a climb than while on the flats. Also, you can always tuck to get more aerodynamic, but you can't ride through a hill :)
if you are climbing out of the saddle. Which BTW is one of the things that makes hill climbing easier.....you can rest ione set of muscles (seated climbing) by using a different technique (standing climbing. Can't do that into a headwind. In addition, you get to rest downhill on a climbing course........with a headwind, no resst at all until you turn to come home.
Len
Failboat Captian
+1 Even though the effort feels about the same, there's a whole lot more satisfaction getting up a hill than there is pounding into the wind. And I'm tall, so headwinds make for extra suckage.
About the only time I like a headwind is when it's >100 deg F and humid. Luckily, those days should be behind us until next year.
Premium Member
Hills versus wind -- it's like the devil that you know versus the devil that you don't know. I will leave the physics to others. But, I will take hills any day over wind. At least with a hill, you know how long and how high it is. With the wind, you never know how long it is going to last and it can change without warning. And, as the song from the '60s goes: "What goes up must come down." However, when it comes to wind, it seems like it almost always is blowing in my face. I sometimes doubt that tailwinds actually exist.
A 150lb rider riding in the drops will need 333 watts to go 15mph in a 20mph wind. The same rider will need 349 watts to go up a 5% grade. However, if the rider is riding on the tops he would require 475 watts which would be like a 7% grade. For riding into the wind how aero you ride makes the most difference, for hills your body weight makes the most difference.
Great thread, I have been wondering that for a while. I live in the great flat lands of South Florida. One of the rides I do is always like 8 miles into a head wind with no protection from the wind, how I hate the section of the ride.
acid_rider: I weigh ~150# and I was averaging ~23kmh into ~35kmh head wind for ~18km distance. Sounds like ~4% gradient?
Are you sure you can hold 23 km/hr into a 35 km/hr headwind for 45 minutes? As mentioned above, this means you can hold 330-340 watts over that time which is absolutley outstanding. As in Cat 1 outstanding!
Of course, 15mph up a nearly 6% grade isn't bad for a mile or so, but to sustain that effort over 10-20+ miles of headwind would be alot of work. At that distance I bet a much more sustainable speed in that much wind is more like 10-12 mph... but that's just recreational me...
All I wanted was a Pepsi!
At which point, the wind magically shifts direction, leaving you speechless in disbelieving frustration (except for the 4-letter words, of course).:mad2: :mad2:
Discussion Starter · #17 ·
no, I am lousy, actually
I am lousy. No Cat anything.
the wind was ranging from 30kmh to gusts of 40kmh (weather station nearby) and the direction was ranging from head-on to ~45 degree angle (it felt like) so I suspect I was nowhere near as good! I would be happy with Cat-4 performance (is there such a thing?). I am but a humble fitness rider so there is no way I can pump out that much power. The computer said 23kmh average though. I was riding 90% on the tops and brake hoods, not drops. I did pass quite a few riders along the way. What I really hate are cross-winds of >35kmh, for safety reasons, but head wind makes you stronger as done climbing.
Missing a key point
The information provided you so far is factually correct, but everyone is missing a key point. The reported wind velocity that you hear is measured 30 feet (10 meters) or so above the ground, and far away from any buildings, trees, hills, or any other object that would affect the wind speed. The practical realities are that when riding a bike, even in very open country, the wind speed that the bike/rider experience is much less than the reported velocity. If there are any trees, houses, bushes, or even crops along the road, wind speeds are even lower. Plus, the wind speed at ground level is, by definition, zero, so we are always riding in a diminished wind space. IME, from knowing how huge an impact a headwind would have in a "wind tunnel" space, I would say that the actual winds we experience as riders are something like 1/4 to 1/3 of the reported wind velocity.
So, for that 20 mph reported headwind, you are more likely seeing 5-7 mph at the bike. All of the numbers you have been given so far do not reflect that, so real world the wind effect is MUCH lower than what has been quoted. It is still huge, but nowhere near as huge as you would believe by plugging headwind speed into analyticcycling, etc.
Granted wind varies from one location to another due to the obstructions. Looking at the different weather station locations that www.wunderground.com uses in my area, many have similar obstructions.
From a ride I took into a strong headwind down the Sacramento Valley, I can tell you it was pretty stiff (15mph+) and it was like a 4-5% grade. I am sure no one was claiming it was 45-60mph.
In some situations buildings and such can increase wind speed as it creates narrow openings for wind to pass through, thus velocity increases. Think how windy it can be in the concrete canyons of major cities.
Comparing wind vs hills also depends on how heavy you are. As everyone knows, heavier cyclists have to work much harder on hills than lighter ones. However, based on my purely anecdotal experience, heavier cyclists seem to hold up better in the wind than lighter ones. I'm not sure about the physics supporting this, but I have observed it time and time again. Some of the best (and lightest) climbers I know absolutely suck when it is windy. And some of the heaviest cyclists I know ride very strong in the wind.
1 - 20 of 28 Posts
