1 - 17 of 17 Posts
waterproof*
Q: what's better: on-bike sprint workout first, then weights, they plyo? or some other sequence?
Long backstory: lost a bunch of leg muscle mass and strength due to illness. Aerobic/threshold is still competitive but I have no sprint strength so I'm re-building.
Plan is on-bike sprint / anaerobic work, plus weights, plus plyo.
Tips?
does sequencing matter?
Anti-Hero
First: Plyometrics. Done properly, they cause very little fatigue, because the physiological stress is mainly neuromuscular... meaning that they modify the way your brain/nerves/muscles work together rather than causing a physical change to the muscle itself. Also, you will see the best results from them if you are not fatigued when you're doing them.
Second and third depend on your goals/priorities.
Personally, I'd choose the bike sprint workout to be second because, like plyometrics, a workout in which you're trying to produce large amounts of force at high rates of speed is best performed when you are not fatigued. Unlike plyometrics, you're more prone to experience fatigue from a cycling workout.
The strength training workout will likely cause some muscle damage, which would lessen your ability (albeit by a pretty small amount) to perform either plyometrics or sprints. However, if you're doing the cycling workout before the weights, you may experience some fatigue, so you may not be able to lift as much... or it may not affect your ability to lift at all... there are a lot of factors at work, so there's really only one way to find out.
I'm a fan of complex training, which takes advantage of the physiological phenomenon of post activation potentiation. It's what's going on in your muscles when you lift something really really heavy, then, when you go to lift something light, you nearly throw it across the room. In that case, you combine your plyometric/power training and strength training.
Example in-season workout for me:
Warm up with some light squats and 1/2 to 3/4 height vertical jumps
3-5 sets alternating the following pairs of exercises:
3-5 reps back squat (~85% 1RM)
5 vertical jumps (some w/countermovement, some from static squat position- 100% effort)
3-5 reps deadlift (~85% 1RM)
3 reps snatch (~70% 1RM) (if you don't know the Olympic lifts, just sub a different plyo)
3-5 reps 1-leg leg press (~70% 1RM, focus on pushing the plate hard/fast enough that it loses contact w/my feet)
3 reps each leg plyometric step-ups (put 1 foot on a box high enough to simulate knee/hip angle @ top position when pedaling)
Each set of the pair is done with no rest period between the two exercises. After each set of the two exercises, you want full recovery, so you rest 2-3 minutes (example- set of squats, rack weight, immediately perform vertical jumps, then take a 3 minute break before the next set of squats/vertical jumps).
Captain Obvious
Andrea138 said:
I'm a fan of complex training, which takes advantage of the physiological phenomenon of post activation potentiation. .
try saying that 3x fast.
if i do this, will i be able to walk?
Captain Obvious
iliveonnitro said:
Quickest way to end a thread on weight training is to have Andrea respond.
Carry on?
such a thread killer.
waterproof*
Discussion Starter · #8 ·
dear training diary: I ended up doing the sprint workout, then meeting up w/ some clubbies, who told me one of our guys had been hit, so I went home and worked the phones.
What Would Google Do.
Andrea138 said:
I say that all the time when I lecture, so I'm pretty used to it :D
care to share your area of expertise? (for the board)
Anti-Hero
Master's degree in Health & Sport Science
Now I teach Exercise Physiology (basically, what happens in your body when you exercise) and Advanced Methods of Strength and Conditioning (applying exercise physiology to design periodized training programs for athletes)
waterproof*
Discussion Starter · #11 ·
and an accomplished athlete in at least 2 different sports, which she's too modest to mention.
Thanks for sharing that, its nice to know :)
and now I know why you kill threads like this as Nitro and others said! :D
F1000SL
Andrea score's big
nothing like books and degrees:thumbsup: and then real world experience.:D
1 - 17 of 17 Posts
