I recently got a Contour ROAM2 that I mounted on my stem, and I've noticed on the first few rides that the camera and mount together will rotate counterclockswise (camera is mounted on its side to the left) whenever I hit large enough bumps. I'm using the strap mount located here:
Amazon.com: Contour 2755 Flex Strap Mount for Contour Cameras: Camera & Photo
I can't pull the strap any tighter, so I was wondering if you think I should ditch and use heavy duty rubber bands that I can get as tight as I like or if there is something I can wedge between the mount and the stem to make it tighter.
