1 - 5 of 5 Posts
Forgive me for the awful first post.
I use the stand with my back against the wall method and use a framing square. I slide the square waaayy up there and put pressure against the pelvis. I guess it's actually my tail bone really. Anyway, is this the correct way to measure the inseam? I mean, how much pressure against the pelvis should there be?
I'm 5' 7" and I get around 32" with this method, but it's not fun.
I've been riding mountain bikes since 1993, and am realizing a road bike is in order too. Can I take certain measurements from my mountain bike to help me figure out desired measurements for a road frame?
Yeah, I have my wife or one of my kids mark the wall at the top of the square. I figured the width of the book could influence the measurement, so I figured I'd use something real narrow.
What is the make & model of the frame you have, and what size is it? My friend's brother-in-law is a Fuji dealer, so I'm probably going to lean that direction. My friend rides a 54cm Team Pro, with original stem and bars. I'm planning on taking it for a short spin around the neighborhood to determine if that is the correct size for me. When I first starting mountain biking, I road a fully rigid bike and used road bike fitting techniques to set up the stem, bars, seat, etc. However, that was a little while ago and I've forgotten most of that stuff. I'm just trying to refresh my memory so that I can try to get dialed.
Something wider
You are likely getting too high a number unless the framing square is quite wide. A 1" dowel or a book is the standard method.
There is little transfer from MTB measurements to road bike measurements. You'd be much better off to look at one of the on-line fit calculators for a starting point:
http://www.zinncycles.com/fitsystems/default_ie.aspx
http://www.bsn.com/cycling/ergobike.html
http://www.coloradocyclist.com/BikeFit/index.cfm
http://www.sheldonbrown.com/harart-frames.html
http://www.rivbike.com/article/bike_fit/choosing_a_frame_size
http://www.peterwhitecycles.com/fitting.htm
http://www.wrenchscience.com
1 - 5 of 5 Posts
