Hello,
Want to check with the Cr1 owner to see anyone has successfully get 56T front chainring to works with CR1?
I ran into some compatibility issue with a 56T big ring and Centaur front der.
I raise the 05 Centaur double front der to the highest position as possible to accomodate 56T ring, but the teeth still rubbing with the edge of the derailuer outer plate.
According to the campy manual, the Cr1 braze-on mount needs to be high enough to accomodate the 56T. Looks like it's the function CR1 braze-on (how far from the BB do Scott rivet the braze-on), not the derailuer itself.
Does the CR1 rated to support 56T ring?
