1 - 13 of 13 Posts
I just noticed a crack (broken weld) along the bottom bracket of my 7005 Alum. frame. Please tell me this if fixable? I REALLY don't want to go thru the hassle of replacing this bike (tandem). It's not under warranty.
Can't it simply be welded?
not repairable IIRC, AL frames are heat treated and a TIG weld repair would destroy that...it might be possible somehow to have the heat treatment and paint redone but that would cost waaay more than a new frame
I forget the name, but on MTBR in the SS forum - FAQ
There is someone there that does repair work on aluminum frames.
He also retrofits standard BB to EBB for SS use.
I would start there.
A friend just told me about his broken C'dale tandem - broken at the bottom bracket just like Slowmo's. Either these bikes have problems or he is Slowmo. Where does Slowmo live?
Throw the frame in the recycling bin. I've busted two Cannondale frames (f course, getting hit by a car would probably bust any frame, so maybe that shouldn't count). For aluminum frames, this is the price you pay for lightness.
It certainly can be fixed but it might not make much sense to do so.
It would need to be rewelded, heat treated and then get a complete refinish. Even after all this you won't have a new bike but one that will be more prone to the problem you had in the first place.
I'm sorry but I think it's time for a new frame.
dave
It could be repaired. But why? The money and time it will take you to have it done properly could be better used toward a new frame of any material.
Some things have short life spans. Your frame is one of them. If your frame lacks a warranty whether it's used or off-brand, now would be your opportunity to move on.
Take what you've learned about this frame and get a new one.
Discussion Starter · #11 ·
Thanks for the replies. I haven't had this bike too long (okay, one week to be exact), and it truly has less than 100 miles on it. Set in a guys garage for the past 7 years (it's an 02 model). It wasn't cracked when I got it - I checked it all out thoroughly - especially the bottom bracket; so I'm not going back to him to claim my money back. The entire weld isn't broke, but I hate to be in the middle of nowhere with my 9 yr old the back and it break all the way.
It's just bad karma I guess.
POGUE MAHONE
Are you sure it's the metal that's cracked? I've had more than one aluminum frame where I thought the weld was broken, cleaning some of the paint away revealed it was just the finish not the metal that was cracked.
1 - 13 of 13 Posts
