1 - 5 of 5 Posts
I need this part. I have 9100 cranks. I'm pretty sure these are the same despite the price difference. Am I wrong?
479065
479064
I believe the Dura Ace one is metal, the Ultegra is plastic. In terms of weight, they're the same. But when you go to use them, you will notice that alloy one gives a firmer feeling. It's similar to the difference between tightening down alloy handlebars vs carbon handlebars, with alloy, the bolt stop is quite clear and firm, where as with carbon you can just keep cranking until you overtorque and crack the bar.
'brifter' is f'ing stupid
These are both plastic. They are different part #'s so I have no idea if they'll be compatible. My guess is they are but I don't know for sure.
There's a Type A and Type B. Those both look like a Type B.
I think earlier model spindles had shorter internal threads. If you have the deeper threads I guess you could use either fixing bolt. If you have the shallow threads you'd need the short bolt.
Model A: A-Type 8.5mm (Short)
-Dura Ace FC-9000 / FC-7950 / FC-7900
-Ultegra FC-6650-G / FC-6700
Shimano Item # Y1KY08000
UPC: 689228285255
Model B: B-Type 16mm (Long)
-Dura Ace FC-9000 / FC-R9100
-Ultegra FC-6800
Shimano Item # Y1N218000
UPC: 689228404588
1 - 5 of 5 Posts
