1 - 4 of 4 Posts
What would be the effects/drawbacks of going from a 170 to 175 crank? No particular reason other than that i got a really good price on a crank upgrade from a friend. I don' t really see it being much of an issue when i hold the crankarms up to each other, esp as it is a touring/commuter bike. Obviously an inexperienced mechanice here. Thoughts?
Resident Curmudgeon
They should be a direct swap, assuming the brands are the same. If they're not, you'll probably need chain rings, too. You likely will notice little or no difference.
basically swapped a 105 50-42-32 for a sugino xd 600 48-36-26 on my trek 520. the 105 was 170mm but the sugino is 175. do you think it will be much difference? i don't think so as my jamis nova was also a 55cm bike with 175mm xt crank. thoughts?
Does it matter?
you should probably lower your saddle by 5mm to help the transition to the longer crank (leg extension), and move the saddle forward 1-2 mm depending on seat angle (knee position). second thought, just move the saddle down 5mm first. then ride and see and feel from there.
1 - 4 of 4 Posts
