ericm979 said:
The crank is probably toast- once loose the splines will wear quickly.
Going to respectfully disagree. Not going to defend the design as obviously with so many posts about loose crankarms, FSA missed the mark but I will say that those with SLK light and K-Force light that includes a redesigned BB-8200 bottom bracket are not reporting this issue. As for following FSA's assembly instructions - that is probably what got the orginal poster to this point in the first place and it seems obvious that it is time to think outside the box in order to get the cranks properly installed. To that end I will offer the same advice I gave to another forum member from this thread -
https://forums.roadbikereview.com/showthread.php?t=135068&highlight=FSA+crank+arm+loosening - linked above.
Based on my experience with my FSA SRM Pro, K-Force, SLK and K-Force Light - all orginally with BB-8000 bottom brackets except for the K-Force Light crankset which comes with the new BB-8200 - reference the diagram below in which the splines on the spindle are circuled for emphasis:
Regardless of which bottom bracket is being used - original BB-8000 or BB-8200 - when the spindle is inserted into the bearing cups of the bottom bracket, look at the splines as they protrude from the non-drive side bearing cover. If you cannot see the splines as well as 3-5mm of smooth/non-splined spindle protruding from the plastic bearing shield, then proper torque of the non-drive side crankarm will not be possible as the crankarm will start binding against the face of the bearings long before the crankarm is able to fully seat on the splined end of the spindle!
In my experience, when I tighten the crank bolt, the crankarm seats completely afterwhich the crankarm bolt bottoms at which point any additional torque will do nothing but fatigue the bolt and most likely result in a cracked crankarm bolt (yes I have done this)! For the orginal poster, read the linked thread and the OP does not feel comfortable removing the crankarm to inspect the splines, take the bike back to the LBS and ask to look over the techs shoulder when the crankarm is removed because inadequate spindle clearance on the non-drive side will prevent proper installation. finally, FSA has a 2-year warranty on these cranks and while they prefer dealing with bike shops, there is no reason that a consumer cannot call to get a warranty issue resolved.
