The cranks on my bianchi pista seem kind of warped. There's a slight wobble. What's a good set of light cranks to replace them with?
Thanks
Thanks
Those cranks and the Wood BB will cost more than the Pista did new. - TFChase15.5 said:Sugino 75's, Dura-Ace (Track), Campy Record (Track) are all good cranks. The Sugino 75's are probably the least expensive of the three. Buy a Phil Wood Ti/Mag bottom bracket with any of these cranks and it should lighten it a bit...
I don't understand how a wobble in a crank would be fixed by replacing the crank. Is the crank bent? If it were bent, it doesn't seem like it would wobble, it would just rotate in a different plane than the one that it should be in. I suppose the bottom bracket could be skewed to make the crank appear to wobble, but that would be a pretty dramatic event, I think. What are the other symptoms of the problem?wolfereeno said:The cranks on my bianchi pista seem kind of warped. There's a slight wobble. What's a good set of light cranks to replace them with?
