Hey guys - I need some technical info on crank types.
Can I swap out my 2008 Kona Jake the Snake FSA Gossamer MegaExo Compact 46/36 with a Ritchey WCS Road V Crank 50/34 compact double? Trying to keep the same B/B (FSA MegaExo) if possible. Long story short, I need more top end gear for the flats and low end for climbing. I have never done a crank removal before. My first glance at the two cranks looks like they are not compatible
The Ritchey's are Shimano Octalink compatible I think. Not sure about the FSA Gossamer though. Are there any special tools I need to remove the sprockets/arms? Will I need to replace my chain with a longer one?
The other thing I am worried about is the Ritchey's are 172.5mm arm length and my FSA's are 165mm, is this something that could effect my bike setup/ergonomics, mainly my knees? Seems like I would have more leverage....with the 172 jobbies
I am a newbie......any simple input on this matter is greatly appreciated.
Was going to try and do the swap myself instead of LBS. Save a little $$
Thanks in advance.
Cheers! :thumbsup:
Thanks in advance.
Cheers! :thumbsup:
