Any recommendations for a crankset for a fixie? I'll trying to spend as little as possible. thanks!
Any standard road crankset will work. Just use 1 chainring on either the inner or outer postion. The only thing you need to buy is short stack BMX chainring bolts. They are usually $5-10 at an LBS. I prefer using a standard road crankarms because it's easier to get a good chain line with the two ring postions.mexican-JUMPING-frijoles said:Any recommendations for a crankset for a fixie? I'll trying to spend as little as possible. thanks!
