Crankset: Truvativ Elita GXP
Problem: After about 2 hrs of riding the other day, it appeared as if the spindle was starting to work it's way out the drive side crank arm revealing a gap between the outermost edge of the crank and the "lip" of the spindle (maybe 2-3 mm). Crank bolt on the non-drive side is tight and there is no play in the cranks...everything "feels" normal. Just not sure why that would be sliding out.
I was able to get the spindle seated on the crank arm again, but after another ride, it did it again. Any thoughts? I'll be going for a ride tomorrow and if it happens again, I will take a pic and post it, but thought I'd throw this out here for some input in the meantime.
Thanks in advance! Maybe it's time to convince my wife a new crankset is needed :idea:
