Hi!
I've got a Bristol Windsor AL 7005 frame that I built up with a full Shimano Ultegra group set.
10 speed cassette.
This is the Ultegra Hollowlink II crankset with the External BB bearings. And also Shimano Ultegra pedals.
I've notice that it makes a creaking/popping sound only when I'm out of the saddle and climbing or putting my full bodyweight on the pedals. It's a 56cm frame and I'm just shy of 6 ft and weigh about 160lbs.
I verified the external BB bearings are torqued properly and that the pedals are also tight. Also verified that the two bolts which fix the non-drive side crank arm are tight yet I'm still getting the creak/pop.
Any recommendations would be greatly appreciated as I'm sure my LBS will not be thrilled to work on a "home built" bike.
10 speed cassette.
