fixintogo said:I mounted some Michelin Jets on my commuter - I'm running Salsa Delgado X rims. Do you have to use the larger 700 x 28-30 tubes, or can you get away with 700 x 18-23 road tubes? Thanks
I have used Fix-A-Flat with a presta-to-schrader (or vice versa) nozzle to inflate MTB tires. Fix-A-Flat is a can of compressed air with latex (I think) sealant.isospeed said:I believe 'cross tubes are less susceptible to flatting than road tubes, especially pinch flats. A lighter rider using higher tire pressure may have less problems than if you tried to run low pressure. A side note - some people like to use sealant (stans, etc.) in their tubes. To run sealant you need a tube with a removable valve. I'm not aware of any 'cross size tubes with removable valves - I think you'd have to use a Conti road tube.
