I'm building my 2013 C59 and was wondering if someone can answer a question I have. The top tube has internal brake cable runs. When running brake cable thru hole do you use casing thru the whole top tube out the other end? Or do you cut casing at opening and run cable to other opening then install casing again at the hole? Also, if you cut casing at hole do you use ferrules at hole or just stick casing into hole for a good fit? Any help would be appreciated.
Mar
Mar
