1 - 16 of 16 Posts
steel road, fixie, & MTB
'cross tire options: 23mm, 25mm, or 26mm?
are there any "decent" 'cross 700c tire options in: 23mm, 25mm, or 26mm? that can be used to climb dirt hills with? in mud?
TrailNut said:
are there any "decent" cx 700c tire options in: 23mm, 25mm, or 26mm? that can be used to climb dirt hills with? in mud?
A tire that small would not be useful for offroad use. Vittoria makes a 27mm tire that will just fit on some road bikes (I can only imagine that this is what you're trying to do here...). It is quite small, and must be run at very high pressures to avoid pinch flats. This also goes for any small sized clicher "cx" tire- although they may have knobs they don't function well offroad because they must be run very hard and therefore provide none of the suspension, cornering and traction advantages of a regular cross tire (30mm+). Furthermore, even if the tire will fit in the fork/frame/brake the clearance will be very tight and you'll be amazed at how much mud, small stones, etc. can get pulled in there when riding offroad.
Ditto what Wunlap said. I rode those pinner-sized Vittoria's and they were no fun...anywhere.
The only reason I'd consider CX tires that narrow is if you're trying to cram CX tires on a road.
trying to cram 'cross tires on a track
exactly
i'd be riding my MTB if i was planning on dirt riding, but sometimes when i'm on my road bike i get the urge to "hit dirt"...and i know i would get that way even with a track bike
I too mix road and offroad in the same ride and have the following recommendations:
Try Vittoria XN pro clincher in 30 mm - they come up much smaller eg 27/28 mm and feature a diamond tread that rolls really fast on road, but has an amazing amount of grip even in mud. Wear is perhaps not too good though.
Alternatively, Tufo D28 tubular clinchers (diamond pattern) roll great and have a nice feel on the road due to tubeless contraction. Just remember to get some Tufo gloop to repair any punctures within seconds.
I've wanted to try these for a while: Hutchinson Acrobat. Looks like they would be good on the road, but also good on gravel (as long as it wasn't too steep or loose), and those cornering knobs look like they'd hook up well.
28/30/32 available.
Discussion Starter · #8 ·
28mm Hutchinson Acrobat on a Bianchi Pista?
28/30/32 available.
yes that tire looks like it would work...now only if i knew that 28mm Hutchinson Acrobat would fit a Bianchi Pista, then I can support my LBS and buy it soon...
Pros used 25 to 28mm cyclocross tires for 50 years. That's why they exist but they are all tubeless (no pinch flats).
Administrator
Well in the intervening (15) years since this discussion started, cross bikes expanded the rear triangles and went disc brake so i imagine 34's would be the smallest you would see now. People stick rocking tubulars though- although tubeless seems to be taking over if your not a Pro.
Nobody cares how wide your tires are at a local cx race. In 80+ races I've yet to see anyone have their tire width checked at a race. I suppose there are some elite events where the rules are more stringent but for 99% of people racing cross, tire width isn't a concern. At nationals they've gone to a 38mm rule for everybody but the elites who are still restricted to the 33mm UCI rule. If you're going to nationals and you've got some wide rims (21+mm inside) it's worth checking your tire width. I've got a set of Alex Boondocks wheels that are 23mm inside width and my 33mm tubeless PDX's flare out to 37mm on them.
1 - 16 of 16 Posts
