I don't think so. Another bit of Shimano stupidity. The 7800/7801 hub has inboard bearings on the freehub side whereas pretty much all the rest of DA hubs have outboard bearings on that side.The Flash said:Can you replace the cassette body?
Just an FYI, the 9 speed cassette is actually wider than the 10 speed cassette so you wouldn't need a spacer.. I've never measured a 7800 freehub body so I don't know if it's the same width as other Shimano freehubs.. All other Shimano freehubs need a spacer when using a 10 speed cassette.Clyde250 said:It was advertized as 9,10 speed. If I can get the freehub body off, I can take it to work and get it machined to the smaller splinie level, then just use a spacer to make it 9 speed. Looks like thats the case. Is there any way to just replace the old freehub with a new one that is compatible?
There is nothing 9spd compatible that will fit that hub. If you have cheap/free machine shop at work, you can take it off and get it turned/milled. Refer to Shimano online exploded parts diagram. You will need an 8mm Allen key to remove the freehub once the axle is out. I would say that you would want to take a 9spd cassette, as well as one of your 9 speed hubs as a sample for the machinist.Clyde250 said:It was advertized as 9,10 speed. If I can get the freehub body off, I can take it to work and get it machined to the smaller splinie level, then just use a spacer to make it 9 speed. Looks like thats the case. Is there any way to just replace the old freehub with a new one that is compatible?
