1 - 5 of 5 Posts
Is there away to make a triple shifter work with a double crankset? I did it with my my tri bike but those shifters are not indexed shifter?
Adventure Seeker
You should be able to - you'll have to set the limit screws, and double shift.
The cable pull for shifting the outer two chainrings on a triple derailleur is the same as for a double. So set the shifters up starting with the shifter in the middle position, and the derailleur on the inner ring of the double chainring.
1 - 5 of 5 Posts
