1 - 20 of 27 Posts
I have heard that Australia is getting the Satin Clear (bottom pic) and the team colour. I could be wrong though...have been known to get it wrong (ask g/f)
thanks for the pic, btw
i was curious about the technical specifications, you mentioned some changes from the 010
oh yeah btw a friend was asking about the best place to get a deal on a new 010 ar 1 frameset, i told him i would holla at you....
3T Cycling
Everything on this frame is new. There is a new aluminum alloy, new welding and finishing technique, new geometry, new sizes (48, 51, and 61 now). The F75 shares the same monocoque fork mold as our F1 now, and actually uses the exact same lay up and carbon material as the F4 bike. At 370g, the 1.125 --> 1.5" fork is nicer than most bikes have costing 3x as much. We added the BB30 shell to this model, which didn't save any frame weight, but the Gossamer Pro BB30 crankset shaves nearly 200g from last year's spex, the Shimano R600. The brakes are genuine Shimano 105, a common speciifcation to "cheat" with a house brand spec. Wheels are hand-finished with butted spokes and alloy spoke nipples laced to Mavic's CXP 22S eyeletted rim. The stem and seatpost are the same premium items we use on the F2 level bikes. Handlebars are aerobar friendly for those looking for a multisport option. There isn't much left to comment on other than the price, which remains about the same from 2010.
As for finding a deal, I've always discovered that the best place to buy something that is service oriented is to shop the aftercare and level of treatment/service you'll get after the purchase. That is often far more valuable that saving $100 by driving across town or to another city. I don't have the ability to monitor our thousands of dealers' prices in real time, so I wouldn't know where to begin the search for the "lowest" price anyhow.
-SD
Easy, I asked Dave awhile ago and he said the 75 will have:
1. New frame and geometry
2. New 105 components
3. BB30
4. New handlebar and saddle shape
5. New "side bolt" seatpost
6. Tapered 1.125" --> 1.5" monocoque full carbon fork with carbon dropouts.
Hope that helps a little.
Discussion Starter · #11 ·
dave--
thanks for the info on the specs...is it still 7000 aluminum or did felt "upgrade" to 6000. i've been having debates with some caad 9 5 (soon to be caad 10) guys--imo pound for pound the felt out specs the nine at a much more competitive price. they respond with oh but the felt has a longer head tube. and i'm like, so what, head tube, schmead tube. the main difference between the two models, besides geometry, or the actual shape of the frames, is the carbon stays on the 75 and the 7000 vs 6000 aluminum, felt vs cannondale. i'm curious as to whether felt thinks the 6000 alloy is any better, and in any case, what the composition of the alloy on the '011 75 is...
i also hear what you say about shopping the level of aftercare, never really thought about it that way... this guy is talking about ebay, going down to florida, now going down to philly or dc, he is really shopping price, i guess. i'll be sure to run the aftercare idea by him, maybe look to the local dealers...thanks again
3T Cycling
easyridernyc said:
dave--
The F75 is 7005 series, the F95 is 6061 series. 6000 series certainly has its place. We use it on many of our MTB frames. I'm not sure that Felt has a longer head tube than Cannondale for each specific size. I don't have their geo chart at my fingertips, but from what I recall our F-series geo is comparable to the Cannondale. I'd really like to see a person fit on a Cannondale that couldn't fit a Felt.
-SD
Discussion Starter · #13 ·
that's interesting
when you say "its place" on the 95, i presume you mean the 6000 aluminum in the bars, the stem, and the post, where, of course you have full carbon parts on the 75. the 95 frame is still 7005 alu, unless the '011 is spec'd with 6000 throughout. which leads me to conclude that in constructing its best aluminum bikes
felt chose to go with the quality and cost effective 7000 alternative on both the 75 and 95, investing in carbon upgrades in the fork and stem on the 75, and using 6000 in its place on the bars, post, and fork on the 95. guess that leaves the possiblity that 6061 is better material, although the consensus i get both formal and informal, is that 7000 is slightly stiffer...slightly.
i also gather that the zinc alloy has different properties than the scandium 6061, i got a feeling this debate has gone on before my time...
3T Cycling
easyridernyc said:
that's interesting
when you say "its place" on the 95, i presume you mean the 6000 aluminum in the bars, the stem, and the post, where, of course you have full carbon parts on the 75. the 95 frame is still 7005 alu, unless the '011 is spec'd with 6000 throughout. which leads me to conclude that in constructing its best aluminum bikes Felt chose to go with the quality and cost effective 7000 alternative on both the 75 and 95, investing in carbon upgrades in the fork and stem on the 75, and using 6000 in its place on the bars, post, and fork on the 95. guess that leaves the possiblity that 6061 is better material, although the consensus i get both formal and informal, is that 7000 is slightly stiffer...slightly.
Wow, I guess I lead you astray:
The 2011 F95 frame is made from 6061 heat treated aluminum. The F75 certainly doesn't use full carbon bars and stems, it is a $1500 bike. Only the seatpost uses a carbon fiber mast on the F75, and the fork is a full carbon fiber masterpiece. The fork on the F95 still uses carbon fiber, but it has a more affordable bonded construction with a 7000 series aluminum steerer tube.
We make our most expensive frames from 6061 (full suspension MTB) and our least expensive (beach cruisers). 6061 isn't better...or worse. The raw 6061 material is not nearly as rigid as 7005, but it is more ductile. It is better for mechanical shaping. Once drawn, shaped, welded correctly, and heat treated the strength is pretty similar to 7005. Some of the newer 7000 series Scandium alloys and Li-AL and 7046 aluminum boast some impressive mechanical properties, but like carbon, the crazy stuff lacks real practical application. FEA shows we can get alloy wall thickness down to 0.38mm in low stress zones. Unfortunately, aluminum that thin could be crushed with your hand, so it isn't ideal for most consumer applications. It can hold up to the stresses of being a bicycle, just not real world expectations of the kind of abuse a bike should withstand. I've ridden some 980g Aluminum frames of acceptable performance, but their limitations are the consumers who'd buy them.
In any case, the frame material debate rages on still and will continue regardless of the next wonder-materials' claims.
-SD
Discussion Starter · #15 · (Edited)
so, comparatively speaking, at least in theory....
if you built the 75 with the 6061 aluminum (keeping the fork, post, stays, and hell yeah, the steerer --that's plenty carbon for me)
and compared it with a 75 with 7005 aluminum (again with the same carbon fork, post, stays and hell yeah steerer)...
which do you think would be a better performing bike, qualitatively speaking? i've heard both ways, i think the obvious answer is 7005,although as you say the scandium alloy may ultimately add different dimensions than the 7005 with the zinc....
3T Cycling
The 2011 F75 does not use carbon seat stays. 6061 and 7005 do not use Scandium, either. That's a different kettle of fish altogether.
We'd be at the point where testing machines and protocol would have to tell us the difference because road surface, air pressure, saddle design, and fit would have far greater impact than the alloyed metals in the aluminum raw material of the frame.
I suppose it would be possible to make the F75 more affordable from 6061, maybe that is significant?
-SD
Discussion Starter · #17 ·
sounds like the 011 75 has already been kept affordable, at least in part, by taking out the stays. i see its top tube slopes down into a more relaxed geometry, which gives it a sexier, more modernish profile, but i think i still prefer my 09. i really think the specs, including carbon post, steerer, fork, and stays, along with the compact 105, deliver a dynamite combination that you find nowhere else competitively in the high end market, at least not on any aluminum or aluminum carbon mix that's not named cervelo. man i love riding my felt so much i havent even had a chance to install the fizik saddle and easton 90's (70's would probably work, i might try those on too), but i dont doubt that the upgrades will deliver added pop to an already
awesome machine.
it would be tough to contemplate a third aluminum bike, even a felt, as an addition to the stable, especially when i already have the top (imo) of felt's aluminum line. like i said, i dont think the specs can get any better. but i hear makes good carbon bikes, too...:D
thanks sd
-SD
+1. I know of at least four bike shops that carry Felt and Cannondale. All four of them say the same thing. When they don't have a Felt in a persons's size, they usually give them a C-dale to test because the geometries are that close.
SuperdaveFelt said:
Here you are:
USA is only carrying the Navy Blue color. I'm not sure which countries carry both at this time. That'll be more clear by Eurobike.
Why is the US only carrying the Navy Blue color? I saw the red/matte black and want it bad, it is way sexier! Any idea where I could get one in the red/black color scheme or if my LBS can order one for me? I'm in Northern, CA.
Question for SDave @ Felt - is the Red/Black color combo available directly from Felt? Saw your initial comment that only Blue will be available in US, seems like an obvious statement, but just wondering if that only applied to dealers. I've got my sights set on the F75, and lucky enough to work in the industry and will be able to order directly from Felt.
Thanks in advance for your reply.
1 - 20 of 27 Posts
