1 - 5 of 5 Posts
i want to lighten my bike but dont know where to start.
here is the list of parts:
Frame 100% Cr-Mo, Euro Bottom Bracket (English/Standard Threading), Water Bottle Mount, Front & Rear Fender Mounts (Clearance on Rear is tight, not all fenders will fit) Detailed Pics Gallery
Fork Triple Butted 100% Cr-Mo w/ Fender Mounts
Crankset FSA Vero3-pc Alloy, 170mm, Euro Sealed Bearing, 46T Alloy
Bottom Bracket Semi Cartridge Bearing ST
Pedals Clip and Strap Road as shown
Cassette/Freewheel 16T Freewheel
Chain KMC Z410 Silver
Front / Rear Hub Formula High Flange Alloy, 32H, Sealed Bearing, Nutted/
Formula High Flange Alloy, 32H, Sealed Bearing Nutted, Fixed Flip Flop
Spokes 14G Stainless Steel
Rims Alex R500, 32H, Double Wall w/ CNC Sidewalls
Tires Kenda K176, 700 X 28c
Brake Set Tektro 510A Dual Pivot Caliper F&R
Brake Levers Tektro RX4.1, Alloy, F&R
Headset 1.125inch sealed bearing for threadless steerer
Handlebar Aluminum Alloy Road, 7 Degree Sweep
Stem SE 3D Forged Alloy
Tape/Grip Velo Cushion Wrap Foam
Saddle Dawes Super Light w/ Custom Cover
Seat Post Dawes Micro Adjust Alloy 27.2
Seat Clamp Ultralite alloy - Bolt-on
Carbon Fiber = Explode!
Dude, it's a SS... if it's not light enough as it is... you might as well start over from scratch. Especially since it's a Dawes. No offense or anything.
I say frame, wheels then fork.
Two scoops of inertia.
You could probably shed quite a bit swapping the wheelset, seatpost, and saddle. In my searches I swear I've read about the wheelsets on lower end bikesdirect bikes being anchors. round out the rider/bike interface by making sure the pedals and handlebars are to your liking. Swapping those may offer a few more grams, but comfort/confidence is more a factor there. The bigguns besides that would be a carbon fork and crankset and those will cost too much to justify. you have to consider with half those upgrades you'd be knocking on the door of a Jamis Sputnik's cost and that weighs 16.75 lbs out of the box.
My advice: enjoy your bike for what it is, upgrade whatever hurts or breaks, ride, ride, ride.
Wheels are where the BIGGEST weight savings are...
The wheels you list are going to weigh in the 1200g each category. You can use a lighter front wheel if you want. I use a Campy Proton on the front of my Bianchi Pista. I saved over 500g on that alone. Dropping weight is going to cost you big time though as you would likely need to purchase a lighter crankset/bb and rear wheel as well. To be honest, my fixie weighs 2 pounds more than my geared (Caad8 R5000). On the road, I hardly notice the difference....probably because my fixie (Bianchi Pista) is just so much more fun to ride!
1 - 5 of 5 Posts
