1 - 20 of 29 Posts
Any of you get dead cartridges now then?
Had one from the Crossman box I picked up at Walmart. Good thing I had spares. I've not had this occur before, now it has me thinking a mini pump may be good to have on longer jaunts.
Country of origin?
Made in China? Maybe the cartridges got sick and died from eating Chinese baby formula or from playing with lead-coated toys. :)
Steaming piles of opinion
I've not had it, but I've heard of it from a buddy or two.
The constant to this discussion that I never quite understand is if something isn't reliable, so you choose to carry a backup that works 100% of the time...
Why bother with the something?
Get a good minipump, don't bother with the CO2.
I've been saying this for years, and as far as I know, I haven't convinced one person. A good framefit pump, like a Zefal, will never let you down. My first one lasted 20 years until I ran over it with my truck, and the second one is at least five or six years old.
I think C02 are a total waste. I see young newbies, using those, freezing their hand to the cartridge, blowing the tire off the rim, wasting a cartridge with a bad seal on the valve, and just plain flatting a good tube when a glass was not found in the tire. Some newbs think they dont need a pump if they have 2 C02s. I call them walkers.
hello
Exactly, get a full sized frame pump. :D
i like CO2. I have been using it exclusively since I came over from the fat tires.
Off hand I can recall using CO2 to fill up a tire 6 times without issue.
I carry a CO2 unit. And a mini-pump on one, and a Silca Impero frame-fitting pump on my vintage machine. If I'm shagged-out from the ride and have a ways to go - I'll use the CO2. Other then that - the pump. Simple as that.
By the by - Crossman CO2 carts are usually associated with air-guns by the same maker. I used to have those - both pistol and rifle. The Crossman cartridges for those were notorious for being nearly empty or leak.
eRacer
I love CO2's, but must confess I have messed up more than once using them for whatever reason.
I carry two CO2's and a mini-pump backup. Call it superstition, but since carrying the backup pump, I haven't had a CO2 problem.:thumbsup:
$4000 bike - two bit legs
I've been a frame pump user and CO2 user. I'm only CO2 now. I carry about five cartridges in my wedge pack. "Knock on wood" but I've never run out of cartrigdes on the road. If I'm on a long ride, I might toss an extra or two in my back pocket. I also carry a presta/schraeder converter in case I need to hit a gas station.
I get a dud every now and then. Maybe a few times a year. I always pack 3 or 4 and a mini to seat the tire..I would not rely on co2 by itself..
wow them things realy work?how many does it take to fill a 700cx28 tube?man beacase the frame pump i have wore me out using it
What I do
I use a mini (just about anyone will work) to seat the tire, pump about 40 strokes to get me up to around 30- 40 psi then finish off with a 12g co2..been doing it for years..the best way is to use a couple of cheap 12g cartridges and experiment in your garage a few times..
The problem is..
I agree about a good frame pump, I pack a full length Blackburn on my old Master X-Light. The problem is some of the new bikes can't accommodate a full length frame pump...so you have to go with something else..
your text here
+ eleventy
I use pumps on two of my bikes and CO2's on the other 2 bikes. One time when I had a flat I had replaced the tube and then was going to reinflate it with the CO2. I was using an Innovations Ultraflate holder and when I pressed the trigger to let the air in nothing came out. I wasn't sure what was wrong since I'd never had a bad CO2 before. I happened to have the bottom plastic holder pointing away from me while I started to unscrew it. All of the sudden the thing fires off like a missle and shoots off about 30 yards away! [email protected], sure glad I didn't have it pointing up at my face!
Reason number 4,563 on the 'why compact frames are stupid' list. :D
But seriously, a minipump works fine, if chosen well and used properly. It's not as if the 90 seconds saved by gassing instead of pumping (added to the rest of the tube-changing exercise) really changes the outcome of the day.
I have a new Lezyne Road Drive on my newer carbon bike. I'ts the best mini pump I've ever had. I have not had a flat since I put it on my bike. :aureola:
1 - 20 of 29 Posts
