Jenson USA is blowing out a bunch of products to make room for the latest gear that will be coming in over the next few months. These are last chance deals with low pricing and limited quantities. We've rounded up some of the best deals here.
Click here to shop the entire Jenson USA Warehouse Sale.
SERFAS HAUTE ROUTE FOLDING RACE TIRE - Save 70%
The Serfas Haute Route Race Tire is designed for cyclists that value high-performance tires. It is constructed using Serfas's Volcanic Speed Silica Compound which allows the tire to achieve high speeds and gives it agile cornering grip. It features a smooth tread pattern that provides ultimate performance and 185 TPI that provides a supple ride. If you're looking for the ultimate road racing tire, then look no further.
Original Price: $60.00
Sale Price: $18.00
FOUNDATION 78 COMPOSITE WATER BOTTLE CAGE - Save 45%
Beyond functionally carrying your water, the Foundation 78 Water Bottle Cage has a clean aesthetic that accentuates the lines of your favorite ride. The design creates a flexible cage that makes accessing your bottle quick and easy.
Original Price: $12.00
Sale Price: $6.60
BJORN STAINLESS STEEL RIVAL 1 JENSON USA EXCLUSIVE BUILD - Save 20%
This Jenson USA Exclusive build of the Bjorn Recycled Stainless Steel bike comes expertly spec'd with a SRAM Rival 1 1x11 drivetrain. It features a SRAM Rival 1 shifter, rear derailleur, and crankset. The cassette has a hill-crushing 11-42-tooth gear range that gives excellent climbing gears while also providing a great range for riding rough terrain. The SRAM Rival hydraulic disc brakes provide excellent stopping power so you can descend with confidence. The DT Swiss G 1800 wheels are paired with Kenda Flintridge Pro tires and both can be set up tubeless for a smoother ride, better traction, and fewer puncture flats. So, whether you're looking for a dedicated commuter bike, an all-day adventure bike, or just a fun gravel bike, then you'll want to check out the Bjorn Stainless Steel Jenson USA Exclusive Bike.
Original Price: $3500.00
Sale Price: $2789.00
FOUNDATION BIKE CHAIN CLEANING KIT - Save 30%
The squeaking and extra grime bring down your cool points. Keep your drivetrain is in pristine condition with the Foundation Bike Chain Cleaning Kit. The chain scrubber is easy to operate making it super quick and convenient when it comes to maintaining the bike. The kit comes with the chain scrubber and three brushes, a soft bristle brush to lather up your drivetrain, a frame cleaning sponge with bristles and a gear cleaning brush. The kit is stored away in a black drawstring bag.
Original Price: $39.99
Sale Price: 27.99
SERFAS CO2 REFILLS - Save 60%
Serfas CO2 cartridges are available in either threaded or threadless styles. Having CO2 makes tire inflation quick and easy. Long gone are the days when you have to sit and inflate your tube for 10 minutes with a mini-pump.
Sale Price: $4.80
FOUNDATION HEX WRENCH TOOL SET - Save 40%
The shop grade Foundation 613H8 Hex Wrench Tool Set includes six L-shape hex key wrenches (2-6mm), and an 8mm bit that attaches to the 6mm wrench. The 4/5/6 mm wenches feature a ball driver tip on the long arm for hard to reach bolt heads and a straight tip on the short arm for high torque applications. The Foundation 613H8 Hex Wrench Set includes a handy portable tool organizer/holder for easy access and portability.
Original Price: $7.00
Sale Price: $4.20
NINER RLT 9 STEEL RIVAL 1 JENSON USA EXCLUSIVE BUILD - Save 20%
The RLT 9 Steel is the multi-tool of the bike world. You're able to ride dirt trails, gravel trails, or asphalt. It features a Reynolds 853 steel frame that is lightweight and incredibly durable, a PF30 bottom bracket shell, front and rear fender mounts, and a rear rack mount so you can carry extra gear for longer rides. This Jenson USA Exclusive build comes expertly spec'd with a SRAM Rival 1 1x11-speed drivetrain. This drivetrain performs excellently in a wide variety of terrain and comes with a cassette that has an ultra-wide 11-42T gear range. SRAM Rival hydraulic disc brakes provide excellent stopping power so you can descend with confidence. DT Swiss rims are paired with Kenda Alluvium tires that can be set up tubeless for a smoother ride, better traction, and fewer flats.
Original Price: $3360.00
Sale Price: $2700.00
FOUNDATION BENCH/WALL MOUNT REPAIR STAND - Save 30%
The Foundation Bench/Wall Mount Bike Repair Stand is comprised of super reliable steel with a durable powder coated finish. It can be easily mounted on benches or walls using the flange holes (Lag bolts not included). The clamp can be easily adjusted to fit a variety of top tube and seatpost sizes, and the clamp can be loosened and rotated 360 degrees, to accommodate any number of working positions. The clamp features a large, comfortable hand grip, to secure the bike in place with ease. Grab a Foundation Bench/Wall Mount Bike Repair Stand and start working on your bike!
Original Price: $100.00
Sale Price: $70.00
SHIMANO TL-CT12 CABLE CUTTER - Save 37%
Much like all moving parts on your bike, your cables and your housing are going to wear out eventually. If your cables and housing wear out, then you'll need to replace them in order to keep your bike shifting properly. After you install your new cables, you'll need to cut the ends to keep everything looking nice and clean. The Shimano TL-CT12 allows you to easily cut the outer casing and cables easily. You’ll also be able to pinch end caps quickly, which will save your fingers a lot of pain and agony.
Original Price: $63.00
Sale Price: $39.99
Roadbikereview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
Sale Price: $18.00
Sale Price: $6.60
Sale Price: 27.99
Sale Price: $4.80
Sale Price: $4.20
Sale Price: $70.00
Sale Price: $39.99
