Are you feeling the chill? Much of the United States is in a deep freeze this week. If you're not planning to brave the elements, then you can fight cabin fever by preparing your bikes for warm spring riding.
This is the perfect time of year to stock up on tools and repair essentials to ensure you're ready to hit the trails. We've rounded up the best tool and repair item deals at Jenson USA. For a limited time, you can stock up on tools, tubeless sealant, and even repair stands to build your personal bike shop.
Related: The Best Bike Deals from the REI Winter Clearance Sale - Save up to 50%
FOUNDATION BENCH/WALL MOUNT REPAIR STAND - Save 30%
The Foundation Bench/Wall Mount Bike Repair Stand is comprised of super reliable steel with a durable powder-coated finish. It can be easily mounted on benches or walls using the flange holes (Lag bolts not included). The clamp can be easily adjusted to fit a variety of top tube and seatpost sizes, and the clamp can be loosened and rotated 360 degrees, to accommodate any number of working positions. The clamp features a large, comfortable hand grip, to secure the bike in place with ease.
Original Price: $100.00
Sale Price: $70.00
FOUNDATION HEX WRENCH TOOL SET - Save 40%
The shop grade Foundation 613H8 Hex Wrench Tool Set includes six L-shape hex key wrenches (2-6mm), and an 8mm bit that attaches to the 6mm wrench. The 4/5/6 mm wenches feature a ball driver tip on the long arm for hard to reach bolt heads and a straight tip on the short arm for high torque applications. The Foundation 613H8 Hex Wrench Set includes a handy portable tool organizer/holder for easy access and portability.
Original Price: $7.00
Sale Price: $4.20
ORANGE SEAL ENDURANCE SEALANT W/INJECTOR - Save 9%
Orange Seal Endurance Sealant lasts up to three times longer than other sealants, while still providing the same quick sealing properties you've come to expect from Orange Seal sealants. Not only can it seal large punctures up to 1/4" and perform under varying temperatures and altitudes, but it is also compatible with most bike tire systems and is easy on the planet.
Original Price: $10.00
Sale Price: $9.99
FOUNDATION BIKE REPAIR STAND - Save 30%
Whether you're tuning things up in the garage or making adjustments between races, the Foundation Bike Repair Stand is here to give you a hand! The triangle base and aluminum construction provide a sturdy platform that doesn't rock during repairs, while the head clamp rotates 360 degrees for easy access to all parts of the bike. The included tool tray conveniently attaches to the main shaft of stand keeping all your Foundation Bike Tools for the job within reach. The Foundation Bike Repair Stand folds down quickly and easily for convenient storage and easy carrying.
Original Price: $150.00
Sale Price: $105.00
SRAM AVID HYDRAULIC 5.1 DOT BRAKE FLUID - Save 22%
PitStop by SRAM/Avid is a replacement DOT 5.1 brake fluid for SRAM's line of hydraulic disc brakes (or other systems that use DOT 5.1 fluid).
Original Price: $14.00
Sale Price: $10.99
SRAM PRO BRAKE BLEED KIT - Save 12%
Bleed your hydraulic disc brakes like a pro with the SRAM Pro Brake Bleed Kit. This kit makes quick work of the bleed process. This kit is compatible with SRAM XO, XX, Guide, Level, Code, and SRAM hydraulic road brakes.
Original Price: $95.99
Sale Price: $83.99
FOUNDATION 768 BIKE CABLE CUTTER TOOL - Save 35%
Frayed cable ends got you down? The Foundation 768 Bike Cable Cutter Tool can turn that around. It provides precise, clean cuts to prevent fraying, leaving a smooth, completed end, and saving the capacity of your cables.
Original Price: $25.00
Sale Price: $16.25
FIX IT STICKS MULTI-TOOL WITH BRACKET - Save 10%
Just as useful as they are compact, Fix It Sticks function much like a 3-way wrench, yet have the ability to break down into smaller pieces for easy transport. A Fix It Sticks set comes with 2 sticks, each of which has a different bit at each end. To use, grab the stick with the bit you need and insert the opposite end of the stick into the center HEX hole of the other stick. This effectively creates a mini T-handle wrench, offering far better leverage and torquing capabilities than a traditional multi-tool.
Sale Price: $22.50
FEEDBACK SPORTS CHAIN PIN PRESS - Save 10%
The Feedback Sports Chain Pin Press is made from cast steel, ensuring great durability over the years. It's compatible with 1-12 speed chains and features a spring-loaded retainer.
Original Price: $39.99
Sale Price: $35.99
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
Sale Price: $70.00
Sale Price: $4.20
Sale Price: $9.99
Sale Price: $105.00
Sale Price: $10.99
Sale Price: $83.99
Sale Price: $16.25
Sale Price: $22.50
Sale Price: $35.99
