1 - 20 of 20 Posts
Good news everyone!
I am torn on what I want to do in regards to my weights. I'm getting to the point where I need a set of dumbbells for weight lifting and strength training, and there are a few options I guess. One is to just buy an expensive set of adjustables. It's nice because you can get ones from 2.5 - 120 pounds and just have one set for everything. The downside is that in the smaller weight ranges, like 10-15 pounds the things are just flat out bulky. The other option is to get a set of small adjustables, say one that runs from 2-25 pounds, and then purchase separate dumbbells for the heavier weights, say 30-75 pounds, or larger if the need arises. I actually think that's the cheapest and easiest route, and the one recommended by the guy at the fitness store. What are you guys using? Are the adjustables even worth it?
I ride in circles..
Adjustable weights suck... Forget to click the weight in correctly and have a plate slam your toe and you'll see why.
I thought they were pretty cool initially but after playing with a set in Dicks Sporting Goods I will never own a set.. but that's just me..
Yeah, when I was into P90x pretty hard I looked all over for decent adjustable weights. They don't really exist. I went with the basic bar/weights combo. Takes up room, doesn't change easily, but is about 1/4 the price.
From what I learned Powerblocks were really the only way to go.
Good news everyone!
rubbersoul said:
Powerblocks are amazing. High quality, very easy changing of weight. Not the cheapest, but you get what you pay for.
Definitely not the cheapest, but considering a full set of dumbbells can easily run you a grand probably not the worst deal either. My only concern is their overall bulk when in the lighter modes.
I have a set and they are fantastic even just using the core handle section (5 lbs). Never been an issue with any exercise. If you can afford them, its an excellent purchase.
________
Colorado Medical Marijuana Dispensary
I was using a variety of light dumbells over the winter and into the spring and then my wife's coach recommended we simply get a chin up bar and do chinups/pull ups and some pushups for upperbody work...
I think this has worked out much better then the former plan considering we are both focused on cycling and not bodybuilding/sculpting...
Rider5200 said:
Ditto on Powerblocks. Get the stand, too -- your back will thank you later.
I actually work at a specialty fitness store, we sell a ton of powerblocks (probably more than dumbbells). They have a 15 year warranty, and with dumbbells being 0.80-1.50+ per pound, you will normally save 50% or better over a comparable range dumbbell set.
Plus, they have a 15 year warranty and are way more bombproof compared to the knockoffs. (which are about the same price).
-Physiojoe
Good news everyone!
Discussion Starter · #17 ·
Sentinel54 said:
+1 for Powerblocks. I have the 5-90 set and couldn't be happier. They are very pricey as others have stated but completely worth the money.
I was thinking the 5-50 pound ones. I am just not sure at this point in time I would have use for anything larger than 50 pounds. I think I can always upgrade at a later date as well right?
You can do all sorts of things with that pull up bar they sell in the AS SEEN ON TV sections/stores and you can certainly exercises with nothing... i.e. push ups. This site has lots of interesting exercises with lots of different equipment.
http://www.exrx.net/Lists/Directory.html
Personally for me Gold's Gym has all the dumbbells I need... in addition to other stuff.
Edit: forgot to paste in the link
This. The local Y will have all the weights you could ever need, a pool, and cardio equipment should you decide to torture yourself with an elliptical or treadmill during the winter months.
I have a cheap set of dumbbells and a pull-up bar and you can do all kinds of things with that but I prefer a real gym.
1 - 20 of 20 Posts
