1 - 6 of 6 Posts
tdiclub Member
Hope not...here I go.
What are the down sides of spacing out a freehub for singlespeed applications?
I can really find any aside from the asthetics. Tried it out on a campy chorus 9/10 hub laced to a campy moskva rim, works well so far.
The Singlespeed forum over on MTBR is a good resource, plenty of roadies there too. Just warn them of "Roadie Content" from the get go. :D
If I am understanding your question right, aesthetics and a less dished wheel are the advantages of a SS specific wheel. (and weight?)
The advantages of simply adding spacers to a freehub is that it is cheap and you can easily fine tune your chain line.
Premium Member
There really isn't a problem. Most flange to flange measurements are the same as track hubs so strenth isn't an issue...
your text here
unless you REALLY torque, you really dont need even dishing on a SS. you don't even really need it on a fixie if you dont torque hard. but once you start taking off from the line or stopping hard with a fixie, it helps to be centered.
i got away with a converted mtb rear wheel for a SS for about 5 years. had to check for true every month or so, but for doin it on the cheap it was fine.
One thing to consider is that the above average amount ot torque that's generated on a SS is pretty hard on a freewheel/hub. You will eventually wear it out. And when it does, if you're using a BMX freewheel, on a dedicated SS wheel, you can just replace the freewheel. But if you are using a converted freehub, you'll have to replace the entire hub.
1 - 6 of 6 Posts
