1 - 12 of 12 Posts
According to the Park web site I don't (per Park: Some models of Shimano®, Race Face®, FSA®, Truvativ® and SRAM® cranks include the one-key system. No crank puller is required for these systems.), but according to many threads here it seems I do. I have a park CCW-5 crank wrench which is what I thought was all I needed.
I tried to remove the crank last night and as I turned the wrench counter-clockwise, the nut loosened, but then tightened up again. Is that how it is supposed to work, just loosen a bit and then pull off? or should the nut continue to unscrew?
Also, do I need to remove the retaining cap, again per Park I shouldn't.
Please take me through step-by-step. I have looked at other threads on this topic but am still unclear.
Thanks for your help.
NeoRetroGrouch
You were correct; just stopped too soon. You loosened the bolt and then the head butted up against the backside of the 'cap'. Keep turning and it will push the crank off. - TF
EDIT: Make sure that the 'cap' is all the way in (no threads showing) or it may just strip the threads off. - TF
Got it. I will keep turning. The cap is all the way in, I have not touched it. Do I need to be wary of it coming out as I remove the crank?
Banned forever.....or not
If you have the tool to remove the cap, I always take it off, add some grease to the top of the bolt, and reinstall the cap. The crank always comes off easier that way.
Overequipped, underlegged
you don't need it, but i'd get one anyway. Mine cost me 6 bucks and works pretty well, and stripping the dust cap threads can trash your cranks.
I've heard plenty of horror stories about stripping and cross-threading the cranks due to the self-extracting feature.
When I reinstall the cranks, I always take off the one-key remover, so that I can't screw up the Octalink splines. Once I'm sure that that splines are engaged, I put the one-key cap back on.
Discussion Starter · #10 ·
The cranks are off, and everything seems fine. On one side there are maybe 1 -2 threads on the cap are exposed. I will re-install tonight. My plan is to keep the cap on be careful.
Should I grease the threads first?
Is a torque wrench mandatory (please say no as I don't have one)?
Should I put the chain rings on before or after installing the crank?
1) Always a good idea.....(and the splines)
2) No
3) Doesn't matter
1 - 12 of 12 Posts
