ziscwg said:I use the red one of these
They add bling and work really well. They make my Blackburn seem like I'm pumping up my tire by blowing through a straw.
I also carry two tubes because I ride alone a lot.
I only use CO2 for my mtb races.
The only time people use frame pumps is when their CO2 inflator effs up and they use two cartridges without pumping the tire, then they ask me to pump it up with my frame pump. Oh, and the other time is when we're all sick and tired of waiting for them to get enough pressure with their mini pump, and then they ask me to use my frame pump. Other than that, hardly anybody uses a frame pump.francoaa said:I am just getting back into road bike. Do people still use frame pumps? Or is co2? What is a pump to get frame, mini, or co2? If co2 can't that get expensvie? What is a good pump brand?
hmm... I got a Blackburn mini pump and it's a major pain. I should check those out. My frame won't accomodate a regular frame pump. Got a link?ziscwg said:I use the red one of these
Just some added information: rode that bike today, got a flat, and the Topeak Road Morph let me down. On opening it up when I finally got back home, I found that the dry rubber O-ring had rolled off the dry plastic plunger disc. Put the O-ring back on the plunger disc, greased that whole area liberally, re-assembled the pump and all is good again. Moral: if you have a Topeak Road Morph that's not been used for a while, try to pump up something and see if it still works as advertised.wim said:I have the ...Topeak on a bike that will not take a frame pump
Yeah, but if you hadn't given up on your CO2 when IT let you down once you would've had a useful backup today.wim said:Just some added information: rode that bike today, got a flat, and the Topeak Road Morph let me down. On opening it up when I finally got back home, I found that the dry rubber O-ring had rolled off the dry plastic plunger disc. Put the O-ring back on the plunger disc, greased that whole area liberally, re-assembled the pump and all is good again. Moral: if you have a Topeak Road Morph that's not been used for a while, try to pump up something and see if it still works as advertised.![]()
LOL, I thought about that very thing: where's my CO2? Didn't have a long walk home because I was on a group ride and a kind soul let me use her frame pump.PJ352 said:Yeah, but if you hadn't given up on your CO2 when IT let you down once you would've had a useful backup today.
Sorry wim, I couldn't resist (and I hope you didn't have a long walk home).![]()
