Rant in progress. ?"*@@#& This really makes me mad.
You can't trust the manufacturers. Even within their own lines, their number simply aren't accurate.
Trek lists all Madone frames in one (old) chart. But the REAL bicycles do not conform to it. They vary by year with no indication of the variation. For example:
2007 Trek 5.2 in the 50cm frame has a 47 cm measurement from center of crank to the top bar (at a point 4' in front of the seat post). It has a regular seat tube so you can use an aftermarket seatpost to get perfect saddle position if you can start over the 47cm mark.
2009 Trek 5.2 in the 50 cm frame has a 44.5 cm measurement from center of crank to the top bar. [This is a good thing as MORE potential buyers can NOW stand over the bike.] But, the seatpost (mast?) is part of the frame and cannot be altered. The seatcap is also propriatary. For a shorter person (who else rides a 50cm frame???) perfect saddle position is hit or miss as there are no aftermarket parts and no way to lower the mast height although the cap can be moved in one direction (up).
That's an inch of difference. For some riders that inch is crucial. There is NO WAY to learn this important fact without measuring the bike (with a tape measure or your crotch). Even Trek dealers aren't aware of it. Some engineer is, somewhere at Trek, but he's holding the information as a trade secret. That engineer is, no doubt, 6'1" tall and oblivious to the problem.
