<!--StartFragment-->Greetings to all
I currently have twoFelt V85 Adventure Discs (my wife and I)
This model(strangely) does not match the catalogs
Among other thingsthat change are the bushings, front. They should be bearings, but they are cone/ ball type (like a shimano); front hub Felt R3 Disc, sealed bearing, 32H. Therear hub is Felt R3 Disc, sealed bearing, 32H, 11-speed.
After buying them wediscovered they had very little factory fat, so the balls had been damaged. Themechanic changed the balls for others new.
After a trip, theballs are damaged again :mad2::mad2::mad2: I have the doubt if the mechanic used the correctsized balls (currently carries in the front hub balls +/- 5mm)
Can anyone confirmme the ball and socket dimensions of the front and rear hub for this model?
The model is Felt V85 adventure disc, and is supposed to use Felt R3 Disc Hub.
I write from Spain,where it is impossible to find information of this model, since we have theonly two bikes of this model in the country (imported from Germany, andFelt-Spain does not give any information or attention).
(Apologies for thetranslation of google, I hope I have explained)
Thank you very much
<!--EndFragment-->
Thank you very much
<!--EndFragment-->
