I've just finished building up an Argon 18 frameset and found that when installing the front (Dura Ace) calliper, the allen ‘'nut' only threaded onto the very end of the calliper bolt. In other words the fork is quite wide and the drilled recess to house the allen nut was insufficiently deep to allow the nut to thread on to the bolt.
I had two options: get a longer nut or drill the forks. I did the latter with and 10mm metal drill bit, which fitted the recess perfectly. I think it was pretty successful. Is this common practice as forks, especially carbon forks, get wider?
