1 - 4 of 4 Posts
FSA crankset (50/34) and a DA10 11-23 with a DA10 short cage derailleur. Will I have any problems with this setup (chain length, etc)
Just make sure of the position of the cage, straight & a low as possible. Wind the inner limit screw in until the chain grates on the cage. Then fit the cable hand tight. Unwind the limit screw until the chain runs clean in the lowest gear. Then adjust the Outer limit screw to allow the chain to shift up but not overshift.
1 - 4 of 4 Posts
