1 - 10 of 10 Posts
I was on a ride the other day and my ride buddy's rear wheel was making noise. At a rest stop I took a look at it to see if the spokes were loose or it was the disk making the noise.
His spokes seemed quite a bit loose, so since my bike is about the same age (2019 or so) I decided to compare them to mine. Mine seemed loose too.
Mine are as posted on title with straight pull flat bladed spokes. When you grab them by pairs, you can get quite a bit of movement where they cross.
Is this normal on a bike with 8K miles? Anyone know what the typical tension on the DS/NDS is suppose to be or where to find the info?
My bike seems to be handling ok, & I usually am cutting the corners at high speed so I'm a little concerned for the next ride.
Until you tell us what kind of noise it is, it's pretty hard to guess. Spokes can make noises where they cross even in a well-built wheel. Especially an issue with flat bladed spokes. A touch of lube at each cross can solve the problem. But that may not be your problem. 8K miles should not be an issue, but it depends on how well the wheel was built.
Well as loose as they are, oil will definitely quiet the rubbing down. Mine don't make any noise, his does. He's been having issues with disk noise.
I think I could tighten them up if we ever get a rainy spell. I need to know the loading requirements, I wt 175.
A well built wheel shouldn't have any difference in spoke tension at 8000 miles than it did when it was new. Pulling on the spokes to see how tight they are seems pretty subjective. I normally plink them with my fingernail but admittedly that's pretty subjective too. Obviously a spoke tension measuring tool is the right way to do it, and compare vs the spec for the wheels. If they are a DT Spline off the shelf wheel DT should have the specs published somewhere, might have to call them to find out though.
Banned Sock Puppet
I would say your describing the spokes as feeling loose is a lot more concerning to me than some noise from spokes rubbing. But as Srode said, pulling on spokes to see how tight they are seems pretty subjective. Do you have another wheel you can compare the feel to?
Yea, I have a lot of wheels and these feel loose. What is a good target tension is what I'm looking for.
Banned Sock Puppet
Hard to describe "target tension" without numbers as in readings on a tensiometer. As stated before, the feeling of tight or loose is subjective.
If you have one, 120-130kgF on the DS and 50-55kgF on the NDS is where you want to be on an 11-speed symmetrical rim brake wheel.
If you have disc brakes, an asymmetrical rim or both, your DS and NDS numbers will be closer together.
Too vague. But spokes will not all go lose at exactly the same rate so you would not have a true wheel if spoke loosening was a big issue.
And if the wheel was build with them all too lose.....well you have 8000 miles of experience to judge what a problem that is.
Discussion Starter · #9 ·
Thanks, my buddy's wheel is starting to worry him.
Banned Sock Puppet
Very good points here.
1 - 10 of 10 Posts
