The front hub on my FG is DT-Swiss Radial with Sealed Bearings:17 x 26 x 5mm. Hub got wet so I removed Bearings and Rubber Covers. Cleaned balls with solvent and Air-Gun. Any suggestions on lube? I used White lithium, but it seems thick, and slower rotation.
Is there a thin lube that protects, but allows freer rotation. Anyone use oil instead of grease for a better rotation?
Thanks,
john
Thanks,
john
