C-40 said:
I don't get it. Suddenly everyone can't handle standard road bike gearing. Uless a 39/27 low isn't low enough there are only disadvantages.
If I want low gearing without resorting to a triple, but dont want big gaps between gears, a compact is the way to go. I rode the same climb in Italy in 2004 & 2005. In 2004 I was on 42/25 and over geared, in 2005 34/25 and comfortable. More importantly there was a smaller gap between the gears making it possible to climb in the 19 or 21 with a couple of gears below for the steeper sections.
I don't understand these macho comments about not being able to handle a standard crank. Indurain used a triple, many pros used triples on the Angliru, and 36t chainrings were used in the 60's. Even Basso used a Compact in the Tour last year!
It's lighter than a triple, gives almost the same range and is less cumbersome than a triple.
