Looking to get a build kit and can get either of these... leaning towards the easton, but any thoughts would be great. thanks.
Okay, I'll bite - how you can tell the difference?razoredge said:I just bought a Easton Orion wheelset a few months ago and I have been very impressed. One of the few factory wheels that are still handbuilt. You can tell the difference.
I hope this isn't how you think you can tell the difference between machine built and hand built. Because if the spokes aren't so loose that they completely slacken in use, there will be no difference in flex or responsiveness.razoredge said:Spin up fast and absorb road bumps much better than I expected. Flexs ever so slightly when you hammer it and very responsive on descents.
Mark McM said:Okay, I'll bite - how you can tell the difference?
Probably. You can't "fine tune" the stiffness of a wheel without changing the components. Whether a human hand or a robot turned the nipples makes not a whit of difference in how stiff the wheel will be or how it will feel (assuming that the tension is high enough to keep them from slackening in use). Contrary to a common conception, wheel stiffness does not change with tension, so you can't fine tune a wheel by adjusting spoke tension.razoredge said:But then again, maybe it's all in my head.
Velomax called them Comps 2-3 years ago. On RBR they show up as Easton as all the review titles were changed from Velomax to Easton after they were purchased. So, the Comps are a few years old if you see them, but to my knowledge are the same wheel with just different decals.bikerboy337 said:in the review section , there are Easton Circuit and Easton Circuit Comp, both same price, but different descriptions? Are they the same, or are there 2 types of Circuit wheelsets???
thanks..
lee
