I've done a search and couldn't find an answer, here is my question: I'm not to fond of the Easton bearclaw system to adjust the headset (keeps loosening), is there a standard style compression plug that will work with Easton's thinner walled tubes? The steerer tube hole is bigger due to the fork's thin walls, which brand of plug will work? FSA, Reynolds, Profile Design, etc. What about the Use ring-go star? And yes...the stem is torqued down to spec and is not rising
Thanks -Paul
Thanks -Paul
