Is there an easier way to change a set of bars without the hassle of loosening brake and gear cables? In other words, is it feasible for me to undo the cork ribbon and the insulation tape holding the cable housing in place, and then simply unscrew the allen bolts fixing the (Dura Ace) levers to the handlebar clamp. Then all I need to do is replace the bars, install the handlebar fixing clamps to the new bars, attach the levers to the clamps, and tape up the bars. In theory this should work, although I've always done it the long way. Posssible?
