"...Electronic Dura-Ace makes another appearance" - Cycling News
C'mon ... isn't this a moped?!?
Scott in MD said:"Electronic DA...only changing gears" - Changing gears doesn't have anything to propulsion?
I know it's a fine distinction, but in my opinion it's over the line.
It's a long stretch, but I suppose you could make a case for banning electronic shifting by interpreting this UCI rule and defining the terms 'propulsion' and 'electric assistance' in a certain way:Scott in MD said:"...Electronic Dura-Ace makes another appearance" - Cycling News
I have a feeling that UCI has already reviewed it and deemed the system to be legal. A) Shimano wouldn't bring it to market otherwise and B) they wouldn't have had TdF riders on it if it weren't legal.wim said:It's a long stretch, but I suppose you could make a case for banning electronic shifting by interpreting this UCI rule and defining the terms 'propulsion' and 'electric assistance' in a certain way:
Propulsion.
1.3.010 The bicycle shall be propelled solely, through a chainset, by the legs (inferior muscular chain) moving in a circular movement, without electric or other assistance.
No. Changing gears is not propulsion.Scott in MD said:"Electronic DA...only changing gears" - Changing gears doesn't have anything to propulsion?
I doubt the electronic shifting can generate the same force that your finger on a mechanical shifter can unless it is rapid rise and then it would go into an easier gear without any force. That would have to be on heck of a servo in there to match the strength of a finger. Perhaps, you should anticipate your shifting needs a little more in advance. It is just the next step. If you don't like it then don't put it on your bike. :thumbsup:Scott in MD said:Anybody who thinks electronically controlled shifting wouldn't give me an advantage over ME hasn't seen me shift my Stumpjumper rear cog into a smaller/harder gear (*accidentally) in the middle of a steep climb at Gambrill Park, then fall to the ground with my feet lock-clicked into the pedals, then roll off the trail and a short ways down Braddock Mountain...
