2017 Sea Otter Classic
ENVE Road Disc Fork Speed Release
Road Disc Fork Speed Release Thru-Axle
Building upon nearly a decade of experience making the forks, ENVE's latest road disc fork features a modern 32mm of tire clearance, a low axle to crown height of 370mm, internal hose routing, and a light weight one-piece from drop-out to steerer construction developed specifically to handle the demands of disc brakes, rough roads, and large volume tires.
The ENVE Road Disc Fork Speed Release thru-axle features Mavic's Speed Release technology. Speed Release provides a light weight quick release thru-axle system that allows for quick wheel changes and consistent torque on the thru-axle so disc brake spacing will remain consistent across numerous wheel installations.
Here's a breakdown of specs and key features.
  • Wheel Size: 700c
  • Claimed Fork Weight: 445g w/SR axle
  • Rake: 43, 50mm
  • Axle to Crown: 370mm
  • Tire Clearance: 23-32mm
  • Steerer: 1.25" tapered
  • Steerer Length: 350mm
  • Rotor Size: 140 or 160mm
  • Axle: 12x100mm Speed Release
  • Price: $599
Key Features
  • 12x100mm Speed Release axle
  • Available in two rakes
  • Single molded design from dropout to steerer tube
  • Flat-mount Disc Brake compatible with 140, 160mm rotors
ENVE Aero TT Stem
Team Dimension Data Limited Edition SES Aero Bar/Stem Combo
The SES Aero TT Stem was developed to be used in conjunction with the SES Aero TT Handlebar. Both components underwent extensive in-frame development in the wind-tunnel to achieve maximum aerodynamic efficiencies and performance. The SES Aero TT Stem is made from machined aluminum and features ports to route cables and housing through the stem and into the top tube of the bicycle. A structural shroud hides the cables and housing while providing the stem with its efficient shape and streamlined aesthetic. With multiple base bar, arm rest, and extension positions, the SES Aero Bar provides an optimal rider fitment and aero position.
ENVE Aero TT Stem
Handlebar Highlights
  • Weight: 650g
  • Width: 40cm
  • Drop/Rise: +/-21mm
  • Spacers: 5, 10, 20mm
  • Ext angle adjust: +/-15˚
  • Min/Max Pad Width: 125-250mm
  • Min/Max Pad Height: 15-90mm
  • Clamp: 31.8mm
ENVE Aero TT Stem
Stem Features
  • Weight: 490g
  • Length: 85mm
  • Clamp: 31.8mm
  • Angle: -27°
ENVE Aero TT Stem
Bar/Stem Combo
  • Stem & shroud hides exposed cables or hoses
  • Maximum drop without compromised cable routing & performance
  • Weight: 1140g
  • MSRP: $1150
This article is part of RoadBikeReview's coverage of the 2017 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
