1 - 20 of 30 Posts
No team-cest unless 8+!
Alright...
Column A= categorical variable... there are about 38 different categories down maybe... 11,000 rows...
Column B= bool... (1 or blank based on whether or not column A is in the top X percentile... it is an active formula)
I need to count uniques in column A with a 1 in column B outputted to a single cell.
TIA!
Moderatus Puisne
Have fun with visual basic!
Cruzer2424 said:
Alright...
TIA!
Creakyknees said:
Wait, I think you're overthinking this. why not just sort and subtotal on A?
It's in a sheet I can't edit. Well... not edit, but it's a data sheet that gets overwritten often. The "summary" sheet needs to get written so that nothing needs to happen in sheet A every time its overwritten
q_and_a said:
use countif
How do I tell it to only count uniques?
//edit: I was thinking that originally, but I'm not sure how to use the frequency command well enough to make it work.
hit it
Pivot table.....
"Row" is categorical variable on top, bool on bottom
"Data" is Count of Bool
Then use your filter.
No hero that's understood
I'd actually dump the data in access and then the answer is easier using find dups. I'll have to think about it.
Actually, the more I think about it, I'd filter out the b's and filter out the 0's and then count the filtered data.
Discussion Starter · #10 ·
Bleh. I can find the numbers for this specific dataset, but I need the answer via functions so it can be found for future datasets with no added work, which I don't know how to do. :(
I'm fairly certain its going to be a combination of SUM, FREQUENCY and maybe an IF function...
This thread is so hot....
Windrider (Stubborn)
NUTT said:
Pivot table.....
Bingo...than just refresh the pivot table when you have new data.............just include one etra row in the data range.
Shirtcocker
<img src=https://www.untoldentertainment.com/blog/img/2010_03_14/mathIsHard.jpg>
Could I be a Fred?
Counif...
My first post!!
I would be simple about it and use countif:
=countif(range,1)
and that will count all the cells that have a value of 1 in it. Try it out. Typoe 4 rows of data, 1, 0, 1, 1 and use that function and it will return 2.
-Holly
Edit: need to preview my posts first. Type ... and it will return a 3.....
Seat's not level
Pivot table
Put the "B" in the page section
PUt "A" in the rows.
Display the Count in the field.
Select "1" in the page.
Only
Seat's not level
Pivot table
Only the unique records with a 1 will show in the table.
The field will tell you how many times it shows up.
1 - 20 of 30 Posts
