I get back today from a local bike shop and I am in my driveway, get off the bike,lean it against my car and go to remove my water bottle. I hear a blast and had no idea what it was at first, it sounded like a shotgun blast. My rear tire tube had burst.
So, I change the tube, removing the bad tube but removing only one half of the tire bead.
I put roughly 30 psi in the tire and then mount the wheel back on. I go to pump it full and I finish. I screw the Presta knob tight thinking I am done and all of a sudden another blast. The tube burst again. This blast was in my face as I am screwing the cap back on.
I called it quits and will be taking the bike to a bike shop tomorrow to be looked at.
Any guess what could have caused this to happen?
1. Is it my tubes that could be bad? I use QTubes 700cx23-25mm Presta Valve 48mm. I had no problem with this brand in the past, maybe the tubes went bad?
2. I checked the first bad tube and it looks like the puncture is near the stem, but not on the stem.
If there is something sharp on the wheel that is causing the puncture, I figure the bike shop will find out for me and be able to fix it.
In the meantime I was wondering if anyone else had similar blasts with their tubes, this is the first time I ever experienced these loud blasts like this and back to back.
Could it be bad wheels? I'd like to have a rough idea what is going on before the bike shop looks at it. Last time I was at the shop the owner tried to sell me $700 wheels and I don't care to listen to that speech again.
Thanks for any thoughts.
