Fall finds and great gear at Jenson USA
Fall time means changing road and trail conditions and the need for more bite and better glove - well thicker at least. This time also gives us as riders an opportunity to take a look at our machines and replace or update for the new season. There is truly no better time than fall to be out on the trails and in the woods. The changing leaves and the smell in the air begging for hard rides and recovery beers. So outfit yourself and your steed to make this fall something to remember.
Michelin Wild Grip'r 2 Advanced Tire - Tubeless
When you're hungry for a hefty helping of trails with variable conditions, seating up a tire with dirt-locking grip is an essential item on the menu. With the Michelin Wild Grip'r 2 Advanced Tubeless Tire you'll find just that, with rugged lugs to keep you connected through loose berms, slick mud, and dusty desert classics, plus puncture protection for some peace of mind when you dive down backcountry trails laced with debris.
SALE 60% Off $26.00 $64.99
Buy Now
Maxis Aspen EXO/TR Tire - 29in
Minimal rolling resistance, light, and race-ready, the Maxxis Aspen EXO/TR 29in Tire is hungry to gobble up miles of rolling singletrack at top speeds. Affirming that wagon-wheels are the true dominators of cross-cross country, the Aspen packs in low-profile directional lugs in the center tread for rocketing on the straightaways, and aggressive side lugs that keep the confidence high when you barrel into corners. A high-volume casing helps to smooth out rock gardens and jarring root lattices, while EXO protection works to shield you from side punctures. The dual-compound construction means you've got hard, fast-rolling rubber in the center to keep you at top speeds, and extra grip on the sides that keeps you locked into loose berms.
SALE 20% Off $51.20 $64.00
Buy Now
VITTORIA Morsa G Plus TNT Tire - 29in
Step up and drop in on the Vittoria Morsa G Plus TNT 29in Tire. With an audacious open tread and sharp, squared-off knobs, this tire provides an abundance of grip for any enduro or downhill shred session in a wide range of conditions. The knobs also feature ramped leading edges to reduce rolling resistance when you're doing the work instead of gravity.
The Morsa G Plus incorporates Vittoria's TNT casing, which is compatible with both tubes and sealant-based tubeless systems and reinforced with a Kevlar bead and sidewall protection. This tire also boasts the revolutionary new G+ Isotech compound, utilizing graphene within the compound mix to reduce rolling resistance and overall weight, increase durability, and improve grip in wet weather compared to tires without the G+ Isotech compound.
SALE 49% Off $35.49 $69.00
Buy Now
SRAM RED 22 Rim Brake shifter set
The SRAM RED 22 ErgoDynamic Shifters continue SRAM's philosophy of perfecting the interface between rider and bike. For SRAM's top-shelf RED 22 series, everything was scrutinized, including the transition between handlebar and hoods, the grip texture, finger wrap, and the separate interfaces with both the shifter and brake lever. The result is an extremely comfortable, highly individual fit that makes the shifters feel like a natural extension of the rider.
$313.60 SAVE 27 % MSRP $427.00
Buy Now
VITTORIA Corsa G Plus Tire - Clincher
Anyone with a passing interest in cycling tech has probably been exposed to the hype surrounding Vittoria's new quadruple compound design, the heart of which is a thin, nearly transparent layer of carbon called graphene. The claims made for this material have been impressive, but we weren't sure what to think until we got our hands on Vittoria's Corsa G Plus Clincher Tires. Vittoria blends four rubber compounds with the inclusion of graphene for the Corsa G, and, without throwing any hyperbole around, we'd say the difference is very noticeable.
SALE 52% Off $33.05 - $39.95
Buy Now
Fox 32 Float SC Factory 27.5 2019
Suspension technology has come a long way in the short time that it has been around and it keeps getting better every year. The 2019 Fox 32 Float Step-Cast Factory Fork starts at 2.98 pounds, which makes this the lightest cross-country fork that Fox has ever made. It is optimized for 100mm of travel and has a Step-Cast lower leg design and a narrow crown spacing that saves weight. The Kashima coating of the Factory series makes the fork buttery smooth and incredibly durable. With FIT4, you can adjust your compression damping on the fly. It gives you an open, medium, and firm option so you can adapt to different trail conditions.
$495.99 SAVE 45 % MSRP $899.00
Buy Now
Fox Float DPS Turnion Factory 2019
With a new and improved EVOL air sleeve, Fox's 2019 DPS Factory Rear Shock offers increased responsiveness and sensitivity. The updated valve design delivers improved compression and rebounds flow, and the Factory series comes complete with a Genuine Kashima Coat. With this model, you also get an additional 3 clicks of low-speed compression to fine-tune the Open mode performance.
$249.99 SAVE 45 % MSRP $453.00
Buy Now
Shimano XTR Trail Brake
To provide highly adjustable, high-powered braking performance with no compromise, Shimano designed the XTR Trail M9020 hydraulic disc brakes. The integration of Servo-Wave brake-boosting technology into an XTR M9020 Trail brake generates gobs of lightweight stopping power (125 percent of the previous XTR benchmark, to be exact) that can be precisely rolled on and off with single-finger effort-giving you a better grip on the bar and ultimately better control of your ride.
$149.99 SAVE 50 % MSRP $299.99
Buy Now
Enve M735 32H DT240 Boost wheelset
Meet the future of gravity riding and racing, the M735. It is incredibly strong and debuts the most effective and lightest ant-flat system currently on the market (Enve's patent-pending protective rim strip). the rim strip on the M735 offers unprecedented pinch flat resistance and provides you with the ability to run lower pressure to improve traction and rolling resistance. It also provides your precious rim a buffer between it and the trail in case you somehow end up flatting out. Ride without limits or restrictions and go all out as you were born to do. Your confidence in cornering and plowing through rock gardens will certainly get a boost.
$1,699.99 SAVE 41 % MSRP $2,900.00
Buy Now
Shimano XT Brakeset
Riding comfortably at white-knuckle speeds requires unconscious, intuitive confidence in your machine. It requires knowing that whatever conditions you come across, your brakes will be ready and able to deliver reliable control in any situation. Say hello to the Shimano XT M8000 Brakes, and say goodbye to compromise. The integration of Servo-Wave brake-boosting technology into XT brakes delivers gobs of lightweight stopping power. Where the M8000 steps up from the already industry-standard BR-M785B is through its upgraded, integrated master cylinder which sports a sleeker look, saves weight and frees up valuable handlebar real estate. It also gains a beautiful black finish that will upgrade the look of any bike. With ceramic pistons to increase power, reduce vibrations and shed performance-sapping heat, when coupled with innovative IceTech aluminum-core rotors (sold separately) to even further keep heat buildup at bay, the Shimano XT BR-M8000 brakes maintain cool, quiet performance under fire.
$84.99 SAVE 44 % MSRP $153.00
Buy Now
Giro Empire Women's VR90
When it comes to your pedaling performance, nothing beats wearing a pair of cycling shoes and being clipped into your pedals. The Giro Empire Women's VR90 Shoes are the lightest and most comfortable shoes in Giro's lineup for women who want a high-performance shoe on the trail. They feature a lightweight laced one-piece upper that provides exceptional comfort and an Easton EC90 full carbon outsole with Vibram rubber tread on the bottom for increased grip on and off the pedals. The upper is made with a breathable Evofiber synthetic material.
Price: $99 (marked down from $150) SAVE 30%
Buy Now
Shimano SLX 11-speed cassette
CS-M7000-11 11-speed HYPERGLIDE cassette utilizes lighter aluminum spider construction, aluminum, and steel cogs and is now available in three-wide range gear options: 11-40t, 11-42t, and all new 11-46t. It is lightweight, rigid and designed to deliver the precise, responsive shifting performance and worry-free dependability that off-road riders demand.
Price: $52 (marked down from $70) SAVE 23%
Buy Now
Chromag Backwoods Jersey
The Backwoods Long Sleeve Jersey is an example of this dedication to perfection. Backwoods Jersey features an antibacterial, moisture-wicking fabric that is not only comfortable but also helps keep you cool and dry. The full-length zipper design allows for easy on and off as well letting you adjust breathability. The semi-tailored fit hangs comfortably without filling restrictive, and the elastic band with silicone gripper at the waist help keep the jersey from riding up.
Price: $32 (marked down from $88) SAVE 63%
Buy Now
Scott SMU Road RC Shoes
The Scott SMU Road RC Shoes are primed for pure speed and produced with elite, racing-oriented riders in mind. They feature a matte finish with an asymmetric welded microfiber and mesh conforming upper for maximum comfort. Dial in the fit with the dual-zone Boa® IP1 lacing system, which allows fly adjustability in two separate segments. The ErgoLogic insole features adjustable arch support and metatarsal button for optimal support and everlasting comfort. With a stiffness index of 10, you're more than set for maximum pedaling efficiency.
Price: $149 (marked down from $350) SAVE 57%
Buy Now
Giro Empire EC90 ACC
The Giro Empire shoes were developed specifically for Taylor Phinney to race at the Giro D'Italia and Olympic Games. The EC90 ACC outsole is stiff and generates maximum power per pedal stroke. The stack height is about 6.5mm, which produces a very close connection between your foot and shoe. The one-piece upper is comprised of a one-piece Premium Evofiber™, which is a breathable microfiber enhanced with perforation. The lace closure is lightweight and provides an unmatched ability to contour to your foot's shape for a close comfortable fit. The SuperNatural Fit technology which is a cycling-specific footbed with an adjustable arch system, for enhanced power transfer. It's light, comfortable, and ready to race.
Price: $99 (marked down from $200) SAVE 50%
Buy Now
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
