1 - 8 of 8 Posts
I am tightening up a Zipp carbon stem. The bolts (Ti I believe) require 6 N-m torque. I have a Park torque wrench (TW-1), which is in kg-cm units
The conversion is: 1 newton meter = 10.197 kilogram centimeter
so basically 60 kg-cm
but at even 30 kg-cm, when I feel how tight they are with a reasonably long hex key, they seem already very tight. I am just now sure I trust, or rather should trust, the torque wrench. Any tips appreciated as I certainly do not want to damage the stem or, conversely, have my bars slip.
Thank you!
I have the same stem and used the tourqe wrench. then checked them with the long allen wrench. they felt nice and snug to me. i could still move the bolts if i had wanted to, but they were not "just barely in there"
i would snug them up and give the bars a nice hard twist. if they don't move you are good. make sure to carry the allen wrench with you, and if they do move, just pull over and adjust them.
Juanmoretime
Use Taxc Dynamic Paste and less torque for slip free grip. I prefer to error on the side of less and the paste allows you less torque and adds grip strength. Why accidentally destroy expensive parts.
Fun and games.
Not as practical a suggestion than the previous posts, but I find helpful sometimes to remind myself what the numbers stand for. 60 kg-cm is a little awkward to translate into reality, but 6 Nm is also about 52 inch-pounds. This means 52 pounds of force applied at 90 degrees to the end of a 1-inch long lever would get you 60 kg-cm or 6 N-m.
A lever twice as long means cutting the force in half, so a 26-pound push at the end of a 2-inch lever would result in the same torque again. The trick is to find out what a 26-pound push on a hex wrench feels to your finger or thumb . . . :D
feel...
It only takes a modest twist with a short handled hex wrench or a 4-5-6 Y-style wrench to produce 6Nm of torque. NEVER use a long handle hex wrench on small M5 bolts. It's not necessary. There have been several reports of misread or malfunctioning torque wrenches resulting in over torqued and broken bolts. I never use a torque wrench on small bolts like these.
Arrogant roadie.....
At work, I have access to a torque tool testing machine, and as a result, my torque wrenches are regularly calibrated. But, for those without access to such a machine, just remember that Torque = force * distance. If you want to see what 5 ft*lbs is on a torque wrench, hang a 5 lb weight exactly 1 foot from the center of rotation. If the wrench goes 'click' at just about 5 lbs, then it's calibrated. BTW, in industries such as machine building, calibrations of torque tools is usually ± 15%, so there is a lot of leeway here.
1 - 8 of 8 Posts
