1 - 9 of 9 Posts
Hi All
i am been riding my AR4 2009 for a year :) and things are looking good. I wonder what kind of wheelset i should change.
Here is the specs for this bike :)
Gloss Gray, White & Carbon
SIZES: 700c x 51, 54, 56, 58, 61cm
Est. WEIGHT: 16.93 lbs.
FRAME: New FELT Aero Road HM High Modulus Modular Carbon Fiber Frame with 3KP Finish, Internal Cable Routing, Carbon Fiber dropouts and replaceable derailleur hanger
FORK: NEW Felt 1.3A Bladed Aero 100% UHM Ultra-High Modulus Fork with Aero Carbon Fiber Blades, Carbon Fiber Crown, Carbon Fiber Steerer Tube, and Carbon Fiber Dropouts, 400 grams
HEADSET: Cane Creek type 1 1/8" Integrated with 20mm Cone and 2 X 7.5mm Spacer Stack
STEM:FELT 3.1 O/S 6061 Alumnim 3D Forged 31.8mm with +/- 8 Degree Rise, 51cm=80mm, 54cm=90mm, 56cm=100mm, 58cm=110mm, 61cm=110mm
HANDLEBAR: FELT 1.3A 2014 Triple Butted Aluminum with Aerodynamic Wing Top Section, with Ergonomic Drop, 31.8mm, 51cm=400mm, 54cm-56cm=420mm, 58cm-61cm=440mm
GRIPS:Felt Gel Ribbon Cork Tape WHITE with FELT 3D Logo
END CAPS: Bubble-Tech Felt Logo End Plugs
SHIFTERS:Shimano Ultegra SL STI, 20 speed
FRONT DERAILLEUR: Shimano Ultegra SL braze-on, double
REAR DERAILLEUR: Shimano Ultegra SL SS Short Cage
CRANKSET: Shimano Ultegra SL, 53/39T; 51cm=170mm, 54cm-56cm=172.5mm, 58cm-60cm=175mm
BB SET: Shimano Ultegra SL Hollowtech-II
CHAIN:Shimano 10-Speed
FREEWHEEL: Shimano 10-Speed Cassette, 11-25T
BRAKE LEVERS: Shimano Ultegra SL STI
BRAKES: Shimano Ultegra SL Super SLR Dual Pivot with Cartridge Brake Shoes
CABLES & HOUSING: Shimano Brake and Derailleur
SADDLE::FELT 1.2 Road Saddle with Carbon Injected Base, Embossed Cover with Carbon Fiber Inserts and Hollow Chrome Moly Rails
SEAT POST:FELT 3.1 Carbon Fiber Bladed Monocoque Design x 310mm
SEAT POST CLAMP: AR Aero 3D Forged Aluminum, 2 x 5mm x 0.8mm Bolts, 16 Grams
F/HUB: Felt AeroR3 Sealed Bearing CNC Machined 7075 Aluminum 20H with Chrome Moly Quick Release Skewer
R/HUB:Felt AeroR3 Sealed Bearing CNC Machined 7075 Aluminum 24H with Chrome Moly Quick Release Skewer
RIMS: Felt AeroR3 700c 27mm Deep Aluminum with CNC Machined Braking Surface, 20H Front/24H Rear
TIRE: Vittoria Rubino Slick Folding 700c x 23c
SPOKES: DT AeroSpeed BLACK butted 1.8/0.9 x 2.3/1.8mm w/ BLACK Alloy Nipples
Aero bike = Areo wheels. The Mavic Cosmic SLs are a great all round package with the aero flange. In at a good price atm at all your favourite money spending internet stores and would go well with you Ultegra level groupset. Not to mention if you have the white graphics too :)
Why?
What are the problems that your current wheels are causing that need fixing? What performance advantages are you looking for that your current wheels don't provide?
i am not sure :>. actually i am not sure what is wrong. i am just considering some upgrades... Any advise.... al i know is to keep riding :)
Cosmic Carbone SL are $850 or less.
Hi
If the Cosmic Carbone SL is interesting, they can be found at Performance for $850, and Bicycle Doctor USA has them under monthly specials on their website for $829. They also indicate 2009 versions may be available for $799.
http://www.performancebike.com/bikes//Product_10052_10551_1099992_-1___
http://www.bicycledoctorusa.com/
The Cosmic Carbone SLs are clincher and aero, but not that light. I haven't owned them, so I won't comment on their durability.
Regards
JD
Certainty
If you don't have current problems and are not sure what you're trying to accomplish, it might be that upgrades would actually serve no purpose. Just saying.
1 - 9 of 9 Posts
