1 - 4 of 4 Posts
Hi,
I have Felt RSL3 wheel, with Felt R3 rear hub, which I need to remove (dismantle, take off). Can anybody help me how? I already see the bearing (after removed plastic dirt cover) and there are 2 'gaps' opposite each other between bearing and outer body, approx 5 mm long.
I could send picture,when allowed.
Any hints are welcome, thanks in advance.
Martin
Wheel Tire Bicycle Bicycle tire Bicycle hub
Discussion Starter · #2 · (Edited)
Light tap on non-drive side with mullet (wood) helped to remove axle, bearing remained on it. Then I needed to use a special wrench(?, I can provide link to it) to loose nut (clockwise, opposite thread) inside the hub. Removing freewheel outside body, watch 24 outer and 28 inner balls. Also notice spacers/shims.
PS: it seems inside is 11 mm hex wrench, but I did not tried to take it off
Hi,
Martin
Please do you have the specifications for the freehub. I want to purchase a replacement. Or do you have link to an exact replacement I can purchase. thanks
1 - 4 of 4 Posts
