1 - 9 of 9 Posts
I have a bike on the way that will include nice aluminum Honsho fenders. I usually transport my bikes in roof racks that clamp to the fork. I can get a roof rack that doesn't use a full-length tray to accommodate the rear of the front fender. My question relates to the upper front lip of the front fender.
I'm concerned that the wind pressure from driving a couple hundred miles at highway speeds could fatigue, or maybe even bend, the upper lip of the front fender. Am I just being paranoid? I can mount the bike backwards, so the rear fender faces forward. But this would put the wind load on the rear fender stays. Is this any better?
Thanks.
Thanks.
I think you are just being paranoid. Haven't you ever had your bike up to 50+ before? If the fenders didn't buckle then they won't on the roof of your car.
No probs w/plastic Zefals, but with aluminum...
I've carried my singlespeed with plastic fenders up to 80-85 for several hundred miles without any trouble, but I think your concern about aluminum might be valid. Don't see a fix for it, though, except to try it out. As for holding the speed to 50...doesn't seem realistic to me, but I live in the wide open West, where the de facto Interstate limit is 80+.
sunroof?
Thanks.
If you have a sunroof, you might be able to keep an eye on it. I would try driving a little more slowly at first, then see how it goes.
Would a bike bra cover the fender? That might help.
Doug
no worries!
i have a cross bike that doubles as a commuter and tourer with fenders. i drive it regularly on the top of my jeep cherokee on the autobahn at 85-90mph with no issues whatsoever.
No worries unless they start vibrating
The only risk to your Al fenders will come if you get a resonant vibration at a given speed. If the aluminum is subject to continous vibration, it will fatigue. Just wind pressure will not be a problem.
The fenders should be fine
but if you have a mud-flap on the front one, you're gonna have to bend it at about 90 degrees to clear the tray. I've found this to be a minor problem when a crease develops in the flap.
-Ray
Arrogant roadie.....
some solutions:
I have one fork-mount carrier, and one 'standing' carrier on my roof rack. I usually have the 'standing' carrier mounted backwards (makes lifting a complete bike much easier on the passenger side, BTW), which keeps the wind from getting unter a front fender. I have 2 bikes with full fenders, and one of them is a classic roadster that I'm not going to carry using a fork mount.
Also, the fork-mount unit can be mounted backwards......
1 - 9 of 9 Posts
